Has anyone removed and straightened a PTO shaft on a MF 1529 or similar?
   / Has anyone removed and straightened a PTO shaft on a MF 1529 or similar? #11
Replacing the PTO Shaft is a good idea. Good time to change the fluid if its time also. If you don't need to change the fluid you can jack or run the rear wheels up on ramps or any support and let the fluid move forward. You might still have to drain some of the fluid but a lot less.
I'm not familiar with your model but most PTO Shafts come out by taking off the outer holder plate and sliding it out. Sometimes I have to slide on a PTO shaft off an implement and use it to pull the shaft from the rear end, makes it easier to hold onto while pulling or gives you something to pry against up close to the tractor. Good luck.
From Agco parts, it looks like the last element in the bore is a seal, then a collar than a circ-clip. ... no plate. Raising the rear is a good idea. I just changed all of the fluids and filters.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2014 Ag Spray Schaben Sidedresser (A52748)
2014 Ag Spray...
CLARK GCS20MB 4K CUSHION TIRE LPG FORKLIFT (A52472)
CLARK GCS20MB 4K...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
