Toolguy
Platinum Member
638 said:Build a sled out of 2x4s. Load them on the sled and drag sled up the road.
You may have to make more that one trip.
ron
Best idea yet. Fast and safe.
ron
Thats not too steep of a slope -12degree. If it has no side lean it sounds good to me. I would venture you can do it safely in 2 trips.marks said:So here's the situation, I need to move 100 pieces of Hardi Plank siding that is 8 inches wide and 12 feet long, and weigh 20 lbs each, up a 300' gravel road that has a 20% grade. After trying it with some 1x4, it apprears that securing a 2x10 to the ROP and FEL will keep the siding from sagging, and small bundles of 8 pieces each will do the trick. I'm using a JD 870, 28hp, with a 420 FEL. Is there anything I'm not seeing?
madpogue said:^^^^^ Or something similar using the mower deck as the mule, for an even lower center of gravity.
