have a 743 bobcat with a kubota desiel engine that is acting up
   / have a 743 bobcat with a kubota desiel engine that is acting up #1
1973 bobcat model 743
It has been sitting in the cold for a month?? I am clearing snow and ice on roads and it is running as good as it ever has. Then it starts to have signs of losing power after a 1/2 3/4 hour. From there it kinda stutters then quits. repeated attempts to restart result in momentary running then quits again, over and over till it doesn't. cools off and same happens again.?????
   / have a 743 bobcat with a kubota desiel engine that is acting up #2
Check your fuel filter, sounds like summer fuel gelling.
   / have a 743 bobcat with a kubota desiel engine that is acting up #3
Fuel supply. Filter, water separator, plugged line, plugged banjo fitting, crap in the tank. Any or all, but it's a fuel supply problem. Gelled filters don't ungel on their own.
   / have a 743 bobcat with a kubota desiel engine that is acting up #4
Vote with the above advice.....do a quick check of the fuel system.
I had a similar experience last year in frigid temps with my ASV skidsteer - after about a half hour of use, ithe engine started to bog down consistently. I brought in back into my unheated garage to try to figure it out before it died completely on me. Long story short - I fired up one of those torpedo heaters and directed it under the skidsteer and let it get nice and warm. That did the trick. I can't explain exactly what the problem was, but I think some track component must have had extreme ice build up and was causing resistance.
so....that's another suggestion - try to thaw it out if you can (I don't know cold it was when you had this issue)
   / have a 743 bobcat with a kubota desiel engine that is acting up #5
Could be cold weather fuel issue as mentioned above, also check fuel vent in cap. After it dies on you, loosen the fuel cap slowly and listen for sucking sound.
2000 JOHN DEERE 444H WHEEL LOADER (A52705)
2000 JOHN DEERE...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
UNUSED IRANCH 16" EXCAVATOR RAKE (A54757)
UNUSED IRANCH 16"...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
