have a couple ?'s regarding landscape rake..
   / have a couple ?'s regarding landscape rake.. #11
Re: have a couple ?\'s regarding landscape rake..
exactly. I use my rake on my drive every spring. Setting an aggressive crown is easy with the wheels. Also IMHO a rake works better when the leading teeth are biting deeper than the others allowing material to get "sorted" along the teeth with the undesirable big rocks getting windrowed into the middle, then setting the rake real lite & windrowing them into the ditch.
A few other observations about landscape rakes.
They do not deal with sod well.
They prefer the surface to be chopped up first. Not necessary on a gravel drive. (Unless you have one as hard as mine. All I do is wait until spring, just before it dries up.) Chopping is more necessary on lawn & field repair.
If the tines aren't clanging, it's overloaded. Try going a little faster, if it won't clear, change the setup.
Rakes are not a one pass device. If you need a one pass device, buy a Harley rake for 5 grand. Even then you'll probably need 2 or 3 passes.
Your results may vary...
   / have a couple ?'s regarding landscape rake.. #12
   / have a couple ?'s regarding landscape rake.. #13
You really have to examine the grade your driveway is on. You don't want to just crown the middle if one side is higher than the other. That will result in water standing in the drive and it will rut badly when driven across. /forums/images/graemlins/tongue.gif
   / have a couple ?'s regarding landscape rake.. #14
   / have a couple ?'s regarding landscape rake.. #15
So on a nice downgrade one could get the water to a ditch? Seems like something I might want to check out.
Cheers..Coffeeman
   / have a couple ?'s regarding landscape rake.. #16
Cheers..Coffeeman
   / have a couple ?'s regarding landscape rake.. #17
I have a Woods 5' rake, no wheels. Works great on smoothing out trails, gravel, raking up debris. And it fits on the TSC/Speeco quick hitch.
   / have a couple ?'s regarding landscape rake.. #18
2015 CATERPILLAR 299D SKID STEER (A51246)
2015 CATERPILLAR...
20" Sea Container (A47384)
20" Sea Container...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2000 Wabash National 53ft T/A Dry Van Trailer (A51692)
2000 Wabash...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
