Have You Operated a Large Auger With Your Tractor?
   / Have You Operated a Large Auger With Your Tractor?
Some larger landscaping companies around here use a 24 inch auger for tree planting holes.
Very rural, no landscaping Co.'s here.
I would just hire a contractor to do the job. Its a one time need only, so renting equipment and training yourself saves very little.
The guy that owns the small excavator IS a contracto who mostly builds houses and additions. He uses it for his own footers. If it ever stops raining he's my guy.
Pole barn companies also usually have large augers. If there's one near you you might try them.
Aaron Z
i asked my metal roofing rep(they build pole buildings) and he said the machine guys are job to job with no time for odd jobs like me.
View attachment 661414 this is a rock i found with a 24 auger. It was mounted to skidsteer.
Isnt there any rental yards in your area? I rented a skid steer with 24 auger for $200 for 3 hours use when i set my front porch. Rental yard 20 min away so it wasnt bad. No way my 45 hp kioti would have pushed that auger into the ground
nearest is a 3 hr RT that has whats needed, so it's far cheaper to use the small excavator guy who is local. Per the thread title I began with renting a 24" auger then got cold feet. My 76 yr old back will not be digging these by hand. A HS kid costs $10 hrly so no economy in him on that much shovel work.
This is exactly why I got a M62. I can just throw a HYD auger on the front and drill whatever I want. Rental is 45 min away but doable.
His piers could be 6 feet deep. Good luck with that shovel.
How much more in concrete costs will the horizontal piers cost ya? When I looked at this it was quite a bit more than a vertical cylindrical pier.
Will be 8" sonotubes inserted in either brand of 24" base. Bag mix in 50# bags cause thats what old farts can lift now days and it's a remote site so no ready mix trucks and too far for FEL bucket of readymix.
One son does these calculations for a living as a civil engr so that IS the design for my walls, nothing more or less and lots less mix this route vs. a horizontal footer.
   / Have You Operated a Large Auger With Your Tractor? #27
Speaking of large augers. I have ten power poles down the side of my driveway. I thought they would use a 12" or 18" auger to dig the holes for the poles. Boy - was I ever wrong. A HUGE semi truck with a gigantic hydraulic auger mechanism and a 3" auger. It would auger and also could operate as a rotary hammer.
So they auger/hammer a 3" hole down as deep an necessary. Then they drop some type of electric detonator to the bottom of the hole - fill the hole with high nitrogen fertilizer( I guess). Pack the top tight with dirt and heavy rock. Run the electric connection over to a truck parked about 150 feet from hole. Everybody crawls UNDER the truck and they touch it off. A mighty ROAR - rocks flying everywhere - a cloud of dust. They now have a hole big enough to drop a power pole into.
Eight of the ten poles had to be "developed" by blasting. Basaltic lava bedrock is very close to or at the surface.
At my request - they came down to where I was working on the house and I got to witness two of these operations.
   / Have You Operated a Large Auger With Your Tractor? #28
That is a lot of work for a 3 inch hole.
   / Have You Operated a Large Auger With Your Tractor? #29
How many piers? Get an 8" augur bit, lay out the 24" hole,
drill 3 holes around the perimeter, and use a shovel to finish it?
That is smart thinking. Would 4 holes be better since he needs a 24 inch hole.
   / Have You Operated a Large Auger With Your Tractor? #30
Not sure if you said you had a backhoe on your machine, but here in massachusetts they sell preform footings at local lumber yards. I just used my loader with an eye bolt on top of footing and plopped them right in. The preforms were $90 each and it certainly wasnt worth it to me to buy the $20 big foots and $8 ish tubes, take the time to tape them, set them and spend the time mixing the concrete. If i remember right crete bags are $5 each and i needed 7 per bigfoot and 10” tube. I just dug trench and luckily didnt catch many rocks. Ive done it both ways and the preforms were a huge time saver.
2014 JOHN DEERE 850K WLT CRAWLER DOZER (A52705)
2014 JOHN DEERE...
2018 JLG 450AJ CLEARSKY MANLIFT (A52705)
2018 JLG 450AJ...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A55788)
2005 Isuzu NPR...
New Idea 14A Manure Spreader (A50775)
New Idea 14A...
(3) HAUL PRO DOLLY / CARTS (A54756)
(3) HAUL PRO DOLLY...
John Deere HPX Gator 4x4 Utility Medical Cart (A55787)
John Deere HPX...
