Have you seen the new CK2610?
   / Have you seen the new CK2610? #62
Because I'm about to void the warranty.
I would absolutely love to know all the details about this!
I have the same machine and once warranty is over this is a very good possibility.
PLEASE keep us posted and PM me details on type of items used and issues I might find while doing the same.
   / Have you seen the new CK2610? #63
Tried it with the 8 inch Woodmaxx chipper yesterday, it handles the thing just fine.
No fiddling with the throttle, wide open is 540 RPM. Front end is very light, might get some weight up front when the loader is off.
So far so good, Fred
   / Have you seen the new CK2610? #64
Wonder if the injectors and injection pump are the same size as the tier 3 CK35 as well. If they were hypothetically it would be an easy job to turn up the more fuel screw, to get 35hp, not that it would be legal. ;)
   / Have you seen the new CK2610? #65
Happy with my current tractor, but still curious about how folks are liking this smaller engined Kioti. How's it going so far? Anyone add any upgrades??
   / Have you seen the new CK2610? #66
Used it yesterday, excellent choice for a small tractor; I'd buy another.
No complaints except 2nd and reverse are the only 2 gears that are synchronized.
Still no turbo, no time this Winter.
Regards, Fred
   / Have you seen the new CK2610? #67
Regards, Fred
Thanks for the quick opinion Fred. You probably went the best route for the smaller displacement with a gear trans.
   / Have you seen the new CK2610? #68
Happy with mine so far. Came in handy moving snow the last few months. Now it is time for spring cleanup and driveway work with the grading scraper I will be purchasing soon.
   / Have you seen the new CK2610? #70
friend of mine bought a Kioti 2610, awesome tractor.
http://www.tractorbynet.com/forums/kioti-owning-operating/372245-turning-up-fuel-ck27.html
Hi guys I am from central PA I have a ck 25 and a ck2510 and i have turned up the pump on the CK 25 and yes you get more power I have access to a dyno and I went from 24.7 HP to 32 HP It really smoked when under a good load, It also made the paint burn off the stack so I screwed the screw in to 27 HP and the tractor works fine. I run a 15 K power plant and it has enough power to get the full 15 k out of the plant. the only problem is the Governor drop which is 200 RPMs under full load it will pull down 200 rpm and the governor will hold at that which screws up the cycles and voltage and bumping up the throttle will work fine until the load drops then you have to lower RPMs pain in the but. but it will carry full load. I have used this on the 1000 rpm and the problem is worse except this works well when we are not asking for the full 15k load. No on to the CK2510 it works better on the power plant because the gov drop is around 25 to 50 rpms Now this is a 24.5 hp engine with out computer controlled injector pump. Its actually a 35 HP engine detuned to 24.5. They turned the screw in and still could not meet the emission standard so they brought the max speed to 2600 rpm which is also the red line for the pto the CK 25 runs at 3200 rpm. Now with a shim removed from the timing at the pump I can get 37 out of the engine with also adjusting the screw. The first CK2510s were computer controlled but Kioti found out it was not needed so they took it off the newer ones which mine is. I also no longer have glow plugs they have air intake heaters, using the same principle as the glow plugs as far as the electrics go. the CK25 is gear drive and has been a good tractor and I have a 1000 hrs on the meter. I also had a 2410 which was more of a mower but had the features of the bigger tractor, was not a good tractor for me as it was always broke, so that hoe the CK 2510 came to be. which has been a disaster so fay the first round mowing in the yard I got stuck the FWD was not going in gear so 6 weeks later and many problems getting the parts I have the tractor back now at 50 hours the injector pump developed a leak its a 1000.00 part and is under warranty, Here we are a 50 hours and we are have 2 major issues with this tractor. I have a mmm and I installed the larger Ag tires and boy did that screw thing up all the mower geometry was off. I had to machine new pcs for lifting the deck the tires hit the deck. So I cant raise it up as you could with the borrowed turf tires. I had to make my own brackets to mount the mower on the tractor. It was supposed to use the FEL brackets which I did not get because I did not buy the loader. Kioti does not make separate brackets for my application. What a nightmare I will be running it in two weekends from now for 3 days straight at our tractor show for power with a leaky injector pump, this could get good. Their fuel tank placement leaves a little to be desired cause i need to fill for those 3 days with a five gall can, so I can see fuel being spilled all over the place. At home I have a pump. Well if I can be of help to anyone let me know at kkegris@yahoo.com by the way I am very good friends with my local dealer who is five mile away.
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2014 Dodge Charger Sedan (A53424)
2014 Dodge Charger...
202475 (A54757)
202475 (A54757)
(4) ROLLS OF MISC CARPET (A54757)
(4) ROLLS OF MISC...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2022 Chevrolet...
2003 John Deere 2500A (A54865)
2003 John Deere...
