Having trouble finding cylinder replacement
   / Having trouble finding cylinder replacement #11
I just ran into an issue when replacing a JD lift cylinder for my homemade snow blade. I remember paying about $180.00 22 years ago and thinking WOW but bought it anyway (no internet to speak of back then). Well I replaced it with a cylinder of comparable specification a couple of weeks ago, so I thought. The first time I lifted the blade at 2600 RPMs (plowing RPMs here), while sitting on the tractor I thought the blade was going to fly right over my head. The speed of the up and down was incredibly fast to say the least. I am down to 1/16 inch orifice fittings in the lines now and it is still mighty fast at 2600 RPMs. So, I am assuming the cylinders that JD and others sell for these tractors, especially for blades, have built in flow control and that is where the higher cost comes in. I was talking with Kennyd about this very thing, the ports on the old cylinder look normal so the flow control has to be built in. You get what you pay for in most cases even if you don't know what you are really getting, as in my case 22 years ago.
   / Having trouble finding cylinder replacement #12
I learned from recent experience that a 1/16" (.063) restrictor, which sounds pretty small, will still let a LOT of fluid through in a hurry. :) You might try Tractor Supply's .060 restrictor and add a .030 or so bent wire in the hole to take up at least half of the volume. I ended up home brewing a restrictor of about .025 to slow down the tilt cylinder on my TnT, worked great after that. But the flip side is restrictors generate a lot of fluid heat in a circuit that is frequently used. No big deal in my tilt function, which is only used intermittently. In a loader or other application where a lot of repeat strokes is required, heat might be a problem.
   / Having trouble finding cylinder replacement #13
Why not restrict the lever movement.
Most valves have what is called a feather control, that lets a small amount of fluid flow to give precise control to the attachment.
Speed of cylinder operation is directly related to the GPM's available. The trick is to only let in enough fluid to operate the attachment to your satisfaction. Is the valve matched to the pump flow?
   / Having trouble finding cylinder replacement #14
I am not sure about rebuilding...the piston end threads are gouged up pretty bad....I hit something and overextended the cylinder, ripping out the piston
Something to look out for when troubleshooting this problem is make sure when angled to one side all the way, make sure the collapsed cyl is bottoming out internally rather than the extended cyl being too short of stroke...
If your stroke is too short on the cyls then when angled, the opposing cyl gets mechanically (not hydraulicly) yanked out when you hit something on the opposite side.....Yes/No..?....did I explain this OK?......
Not talking about cushion valve relieving itself (which should be used anyways) but rather mechanically the frame should have stops welded on or the collapsed cyl should bottom out first internally....:thumbsup:
I agree, there should be be some of a stopper on the angling portion to preserve the cylinder in case of the operator error to preserve the cylinder.
I gave up on trying to find a replacement and sent my money to Messicks.
   / Having trouble finding cylinder replacement #16
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
WATER TRAILER (A58214)
2015 SKY TRAK 6036 TELEHANDLER (A58018)
2015 SKY TRAK 6036...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
PALLET OF HOLE SAWS (A58374)
PALLET OF HOLE...
