Hay baler for 40hp tractor
   / Hay baler for 40hp tractor #1
georgia plow boy
Ive got a 3600 ford tractor,I think its a 40hp, its a diesel, I was thinking about maybe baling my own hay and was wondering if someone makes a baler that would work on a tractor that small,
   / Hay baler for 40hp tractor #2
   / Hay baler for 40hp tractor #3
You could run something like my MF-124 small square baler with your 3600. It takes 34 pto hp (min).
I run it with my 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD).
Found the baler on craigslist locally. Paid $2000 and hauled the baler right out of the seller's field (he used in the previous day to bale on his 35 acres).
Thanks for the help, Im looking for an older model, but having trouble finding any info on them, I live in Ga and we have a market bulletin that sells used balers, I wont be able to afford the new ones , and researching all the ones listed is getting time consuming with little info being found on the tractors hp requirements
Thanks again for the help, Im writing down the make and model and I can look for one that's up for sale around my area
   / Hay baler for 40hp tractor #6
My first was MF #9 used it behind a JD B, 430, 520 & 620, works best with 520/620 because of live PTO. I sold it this fall, paid 1500 & 8 years later sold for 1350. I found a NH 273, its newer & I believe makes better bales. You should have plenty of power for any old baler you find.
   / Hay baler for 40hp tractor #8
Any older square baler you buy should be fine behind that tractor. Ken Sweet
   / Hay baler for 40hp tractor #9
I went to several auctions with a friend that really knows his stuff. I found several and all of them turned out to be worn out so bad that it would cost an arm and a leg to get them going again. Buyer beware!
Good luck.
   / Hay baler for 40hp tractor #10
I use a 214WS John Deere baler behind my Ford 4000 diesel; seems to have plenty of power. I'm hoping to get the IH 46 & 47 balers I traded for going; they're twine & wire is so expensive (though most folks in this part of the country use wire). If the 46 & 47 are successful I'll probably sell the JD but if I don't like the twine tie I'll keep the JD and one of the IH for a backup. These were built back in the '60's when lotsa folks used smaller tractors to bale with.
Lew
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A57024)
Ditch Witch 6510A...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
