Hay farming on a small time basis
   / Hay farming on a small time basis #41
I have an old IH 990 7' MoCo. Bought it at an auction for like $425.00. Took it home, greased it, and checked it out. Been mowing with it for 6 years now. Had to replace a bearing and sprocket last year, and the original sickle broke cutting, second cutting this year. I did have an new spare sickle on hand, so down time was only like 30 minutes, including a cool drink.
My back-up is an older 5' Bush Hog brand rotary cutter. The right side unbolts, and were designed this way for mowing hay. It lays it out in a nice windrow. Doesn't chop it all up, but does seem to break the stems some, to aid in drying. Not near as well as the MoCo, but does suffice if needed...
Also the "conditioned' hay seems to be more palatable for the horses, especially the first cutting.
Bought a new tedder 5 years ago. And as FWJ stated, well worth the money. Especially with the horse hay. I want to make sure the hay is dry. No green gobs to mold..., or heat up, and burn the barn down.
My hay is a mix of Rye, alfalfa, and red clover. The 1rst cutting of the rye grass takes much longer than the alfalfa & clover to dry. So I need to fluff it, or get it turned over to dry...
I started my seeding prep. right after the last cutting numerous years ago. I disked over it twice a couple days after a decent rain. Just dry enough to cut decent with my M-F 3 pt. disk, set at full cut. Once longways with the field, then at a 45 degree angle. It helps you keep track of where you're at when seeding... It cut it just enough to open the ground a bit.
I'd checked into "frost seeding", and it worked well for me. I broadcast my particular hay seed mix during the last two weeks of March in this part of the country. Just when it freezes enough to honeycomb the ground at night, but thaw on top, through the day. It pulls the seed right into the ground.
You can "google" it, and will probably find numerous pages on it...
For my purposes, mixed hay is what I'm shooting for.. Something they can munch on, when they are hungry.
If your going for maximum yield, then soil tests are a must.. I can get a soil test for $12.00, and tells me exactly what I need. I just need to let them know what crop I am planting. And your county extension agent can tell you your seed rate too... We're fortunate round here to be able to contact them via the internet..
And as others mentioned... You have to make it when the conditions are right, not at your convenience...
   / Hay farming on a small time basis #43
Mr builder:
I haven't spotted it, yet, but what Tractor are you using for your hay venture. Your picture looks like a JD 110 tlb (am I even close?). I'm considering a purchasing a 110 tlb for small construction jobs and it would be GREAT if I could likewise use it for our 7 acres of 'hay' and other small farm chores. Am using fatherinlaws JD 5301, now but its going to another brotherinlaw for keeps later this winter.
This has been a great thread. Learned Lots of stuff.
   / Hay farming on a small time basis #44
Mr builder:
That may be an insult to him. His backhoe is nearly 3 times the size of a 110. But it's ok. He was going to use his 48hp Cat Challenger and an IH Hay mower I believe, but I'm unsure anymore.
Just kidding about the insult thing, I'm sure it's ok.
Kyle
   / Hay farming on a small time basis #45
Oh! Woops, sorry.
But anyway, what do youse think of using a JD 110 tlb for 'Farm' use (7 ac hay, 1.5 ac garden area, various other mowing ( incl narrow apple orchard rows, hence choice of size in tractor), moving piles of various stuff, digging basement for house, etc.
Thanks.
2018 FORD EXPEDITION (A51406)
2018 FORD...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2014 MAC CXU613 Semi (A50514)
2014 MAC CXU613...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
KSI Conveyor (A52128)
2013 Dodge Journey SXT SUV (A50324)
2013 Dodge Journey...
