Hay operation using Gc2610
   / Hay operation using Gc2610 #11
At $15K for a baler to bale mini bales, I think it outrageously priced. For that amount, one could buy a used old iron tractor and a used square baler and rake and sickle bar cutter.
I would have to agree on that one as well!
   / Hay operation using Gc2610 #12
There is a company in Pa that makes horse drawn equipment, J&K or something like that, that sells a trailer type sickle bar pto mower that would work well. If you mounted a weighted barrel on your front end loader, hung it from chains ect. to press down the windrow as you bail the hay with a round bailer it just might work and would prob. feed better. I gave a GC2400 and have just figured that might work.
   / Hay operation using Gc2610 #13
How much hay could you buy for $15k?
I know it does come down to dollars and cents.15k is alot. I was just wondering if it has been done by anyone on the forum. A cost analysis would have to be done for hay in my area and the demand for the smaller bales.
   / Hay operation using Gc2610 #15
If you take your time and shop right, a person could buy a complete set of older used equipment including a tractor large enough to handle it for 15k.
I was at an auction last summer that a guy could have done it all in one shot. Watched a 65 horse massy loader tractor go for 5500 bucks, the haybine went for about two grand, rake went for a hundred bucks, and the round and square balers each went for a touch over 2000 bucks. All older, but working equipment.
In addition you would get your hay done in probably a fifth of the time that it would take with that little tractor and baler. Food for thought.
All good advice. thanks
   / Hay operation using Gc2610 #17
I don't what all you do with your current tractor but you could sell it and buy a larger tractor and then buy some used hay equipment.
TANK MANIFOLD (A55745)
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2010 Hyundai Elantra Touring Sedan (A55853)
2010 Hyundai...
BUNDLE OF 8" GALVANIZED PIPE (A57192)
BUNDLE OF 8"...
Butterfly Artwork (A55758)
Butterfly Artwork...
