I have a 5 year old Kubota L3010HST. I am going to be doing my own haying starting next year after having had a local farmer doing it for me in the past. I am hoping to get some input on what implements other hay growers like to use on grass hay to be baled in small square bales appropriate for horses.
I have good smooth fields, some minor hills, and the total is about 40 acres. Currently 20 acres is wet due to springs but I will be putting in tile drains (or something similar, still researching, feel free to comment on this too) so I can get more than one cutting per year as well as use some of the field for pasture. The other 20 acres is nice and dry but this is where there are some hills. When cutting walking paths (stop laughing
) with a brush hog, I need to put the tractor in low gear for some of those hills, so that might be an area where I could get into trouble trying to hay it. I know there are implements that this size rig can run but I also know some of those same implements can be a problem due to tractor weight issues, etc. Any info would be helpful. I bought the tractor new so as not to inherit someone else's poor upkeep and am considering doing the same on the implements. While I have a handy boyfriend, fixing broken tines etc might mean a trip to the shop. i.e. expensive. If you think one or more implements is better purchased new for the above reasons, or maybe one or more can be fine when used, that would be helpful as well. Still trying to figure out things like Kicker or not? sickle bar and separate rake/swather or haybine style all in one? Thanks so much in advance, Moxie
