head lights and other things
   / head lights and other things #1
6sunset6
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I think I see why there is talk about how to put lights up on the ROPS. The brush guard on the TC34DA puts a set of big bars right in the middle of the high beams. The loader arms are right where the angled out low beams are.
I will have to run it out in the dark and see what it actually looks like. Would be nice if the guard guys talked to the head lite guys.:rolleyes: Can't have everything in an otherwise perfect machine I guess.
I was out the other doing tractor things and when I was walking back from the barn I noticed a set of nicely space oil drops along the driveway. Long story short it was one of the external hose fittings cross threaded. I have never done that before in my life. I remember thinking it looked a little funny . No harm done just 2 gal of speedy dry on all the spills, that took a while but oil cuts through blacktop really bad.
   / head lights and other things #2
If you don't like putting them on the ROPS you could always drill the hood and mount them there like they used to do on some of the old iron. :)
   / head lights and other things #3
You could also use a fiberglass or metal sunshade. Then you could get the lights further toward the front of the machine where they might be better aimed to do more good. Just another way of looking at things.....
   / head lights and other things #4
Why not mount the h-lamps to the laoder frame... My old fords with laoders have a lamp on the loader frame.. works out nicely.
soundguy
   / head lights and other things #5
An FYI, it won't be long and HID lighting kits will be very affordable for our tractors. I have been keeping my eye on them. Just a year ago, a good setup with 2 lights was running about 300.00. Now, they are down to 129.99 for a pair. When they get below 100.00, I am going for it!
   / head lights and other things #6
For true High Intensity Discharge lights, not just lookalikes?? I would think the automotive aftermarket for auxilliary lights would be snapping them like crazy at even $300 per pair. A set of true HID headlights is around $2000 if you break your BMW.
What brand lights are you talking about, how big are they, and where can I find them?
   / head lights and other things #7
They are available now for under $100.
This is just an example, not vouching for these guys: eBay Motors: HID CONVERSION KIT H1/H3/H4/H7/H10/H11/9005/9006/9007 (item 170156279507 end time Oct-08-07 09:15:02 PDT)
I'd mount on ROPS. What I would do, is purchase a set of lights with a standard bulb type (H1, H4, etc). and then swap out the conventional bulbs with the HID's... question would be where to mount the ballasts so it doesn't look cobbled together. You'd need to protect the electronics from the weather as well.
Ted
   / head lights and other things #8
Interesting. I checked on site on EBay that said US SELLER. The use of English in the material did not serve to support the idea of a US SELLER, by any means.
Before anyone invests in these kits, I suggest you read through David Stern's lighting website. You can search under David Stern. These kits will give the street/boy racer crowd a car that has "HID" lighting, but I doubt if they will come near the performance of real HID lamps so far as lighting up the road. The stock reflector/bulb arrangement is not designed for this type of light output and mostly you will annoy the heck out of oncoming drivers.
On a tractor, they might just be worth the investment.
   / head lights and other things #9
I bought a set of used lights that use an H4 bulb (hi-lo). Going to mount those to the ROPS.
Will most likely buy one of the cheap Chinese HID setups for ~$70 and replace the traditional H4's with the single H4 setup (no hi-lo, just one beam).
It's for the tractor; not worried about blinding my fellow land owners ;)
More info coming soon! (A44572)
More info coming...
Massey Ferguson 275 Tractor w/ Loader (A47809)
Massey Ferguson...
12-16.5 Skidloader Tires (set 4) (A47809)
12-16.5 Skidloader...
2023 Dodge Ram Truck Bed (A47809)
2023 Dodge Ram...
Ford F-250 (A46443)
Ford F-250 (A46443)
JMR Stump Bucket (A47809)
JMR Stump Bucket...
