Heard a SNAP when turning on pavement with diff lock
   / Heard a SNAP when turning on pavement with diff lock #11
Probably not the case, but make sure your lug nuts are tight.
Im not ad worried anymore that I did some major damage. It makes sense that it was just the diff lock disengaging when I heard the snap. Thanks for the replies everyone.
Actually I checked those after buying the tractor and found that two of them were finger tight. Good reminder to keep an eye on them!
   / Heard a SNAP when turning on pavement with diff lock #14
I'm willing to bet dollars to donuts that your diff lock no longer functions properly regardless of pedal position. If possible, safely jack up the rear of the tractor so one wheel is off the ground. With the engine OFF and the gearshift lever in neutral, rotate the raised rear tire by hand, it should spin freely. Then, continue to rotate the tire while pressing down on the diff lock pedal. When the diff lock pin goes into place, the raised wheel should no longer be able to be turned. If you can still turn it, you have some broken internal parts. Because you stated that you have no need to use the lock in the future, this may not be a problem you have to fix. I would recommend changing the fluid and filter though.
   / Heard a SNAP when turning on pavement with diff lock #15
Differential locked (1) turn and (2) pavement don't work well. My differential lock (which involves the rear wheels of a 4WD tractor) only stays engaged when I'm more or less standing in the pedal, useful when I'm in a bog and considering using the FEL to get out but otherwise..... Those vehicles have a true differential lock, say a 4WD Toyota 4runner, state in no uncertain terms that such must be used at slow speeds and only when going more or less straight forward or back, as in getting out of a snowbank, otherwise the warranty on the transmission is void, and I don't blame them - common sense.
   / Heard a SNAP when turning on pavement with diff lock #16
It's broke! Loud snapping noises from the rear end when driving on pavement with the diff. lock engaged means that something broke.
   / Heard a SNAP when turning on pavement with diff lock #17
I remember a friend telling me he had to repair the diff lock on his 7800. Not sure if it was from not letting off the hst pedal so one wheel was spinning as he stepped on the lock or if it was from having it locked in on hard pack surfaces. Either way he said it wasn't just a snap and it broke but it just kept breaking off the ends of teeth (or something inside) until he finally wore them down to the point the diff lock no longer worked.
I think I might drain the oil and take a look for broken metal in either the filter(s) or oil.
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2005 IC Corporation PB105 School Bus (A55852)
2005 IC...
2015V Chevrolet Equinox SUV (A53424)
2015V Chevrolet...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
John Deere 6110M (A53317)
John Deere 6110M...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Looks like your ad blocker is on.
We rely on ads to keep creating quality content for you to enjoy for free.
Please support our site by disabling your ad blocker.
Continue without supporting us
Choose your Ad Blocker
  • Adblock Plus
  • Adblock
  • Adguard
  • Ad Remover
  • Brave
  • Ghostery
  • uBlock Origin
  • uBlock
  • UltraBlock
  • Other
  1. In the extension bar, click the AdBlock Plus icon
  2. Click the large blue toggle for this website
  3. Click refresh
  1. In the extension bar, click the AdBlock icon
  2. Under "Pause on this site" click "Always"
  1. In the extension bar, click on the Adguard icon
  2. Click on the large green toggle for this website
  1. In the extension bar, click on the Ad Remover icon
  2. Click "Disable on This Website"
  1. In the extension bar, click on the orange lion icon
  2. Click the toggle on the top right, shifting from "Up" to "Down"
  1. In the extension bar, click on the Ghostery icon
  2. Click the "Anti-Tracking" shield so it says "Off"
  3. Click the "Ad-Blocking" stop sign so it says "Off"
  4. Refresh the page
  1. In the extension bar, click on the uBlock Origin icon
  2. Click on the big, blue power button
  3. Refresh the page
  1. In the extension bar, click on the uBlock icon
  3. Refresh the page
  1. In the extension bar, click on the UltraBlock icon
  2. Check the "Disable UltraBlock" checkbox
  1. Please disable your Ad Blocker
  2. Disable any DNS blocking tools such as AdGuardDNS or NextDNS
If the prompt is still appearing, please disable any tools or services you are using that block internet ads (e.g. DNS Servers).
