Heat and Air ?
   / Heat and Air ? #31
OKNewGuy,
I live in Piedmont. Same temperature range as you about 12 or 15 miles west of you. we had a new heat and air system installed in our first house, the original was undersized and died about a month after we moved in, it was replaced with a heat pump with gas heat backup. In our new house we had a geothermal unit put in when we built it. Both done by the same HVAC company You might call them for a qoute. They are very good to deal with, and very competitive on price. "Hunter Mechanical and Controls" They are on north Santa Fe next to the Broadway Extension. I don't have any interest in the company other than to provide a good reference to someone who has done very good work for me in the past.
   / Heat and Air ? #32
Dave,
See if the contractor's will do an energy analysis on the house so you can size the needs of the system. Sometimes the analysis is along the lines of every 500 sf of house requires 1 ton of heat pump. That may or may not be true.
Hopefully are resident HVAC guys can talk about getting the right number of tons in the house.
You want to size that heat pump so its not too big. Too Big is bad. It wastes money to buy and run as well as likely keeping you uncomfortable. The heat pump spends the most dollar when it starts up. You don't want the thing starting and stopping frequently.
Those AL windows have GOT to go when you get the money to replace them. We had AL windows in our last house. You froze in the winter and roasted in the summer next to those windows. I made some inserts to put in the windows to cut down on the energy loss but it barlely helped. Our new house has AL wood clad casement windows. You don't feel ANY energy transfer from outside to inside. Windows really impact the comfortable level of a house.
There are a number of free energy usage programs. I have used one called RESFEN. You have to know the efficency numbers or lack there off from for you windows. You can make guesses. I used the program to figure out which windows made the most economic sense base on the cost of the windows and how energy effiecient they where for our house.
The program says our cooling costs is about $96 a year. Right now are base energy usage, all electric is about around $85-95 per month. That is no HVAC usage. When we turn the AC on in another few weeks our energy bill will go up to $125-135 a month. So for three months we do spend about $30 a month to cool the house. The program seems to be accurate.
This is going to differ on how people set the thermastat. Right now our high temps have hit 87ish. Our house might hit 82. This week we will have highs in the lower 80s so the house will stay in the upper 70s. I designed the house to TRY to do this and it seems to work. The AC has not been on yet and I don't think will have to be turned on for another couple of weeks. If I'm lucky. /forums/images/graemlins/grin.gif
Well, that is a long example on how RESFEN could help you pick the HVAC system. The program should get you in the ball park energy usage/price wise and you can compare that number with the different SEER values and costs.
Later,
Dan
   / Heat and Air ?
Hi Piedmont, I am down off Covel and Bryant. I live in a great neighborhood with 5 acre lots, but it is about 2 miles to Target and Lowes. Anyway, I am glad you had good luck with Hunter, it just so happens that they were the guys to diagnose the system. I have used them at past houses and was always very pleased, but this time they have left a bad taste in my mouth. My guy down the street, got me some quotes today, and they are not as bad as I thought they might be. To replace the outdoor unit is $1625(13 seer), to replace everything with ng furnace,inside coil and outside unit (13) is $3500 and to go to 15 seer and a complete new system everywhere is $5600. I do not have all of the model info yet, this was just a quick conversation over the phone. The units would all be American Standard all 3 ton and this is with me being the helper. The warranties are 6 years on the partial and 10 years on the complete new system. Hunter is getting me a quote, and I will use that as a gage.
I am definetly planning to upgrade my windows, and increase my attic insulation. I had checked into geo a couple of years ago, and it sounded like the ducting would not be adequate. If I was building new, I really would think about it thou. BTW, the house has stayed cooler since I got the roof ventilator working.
Any thoughts on the 13 to 15 cost difference, and how long it might take to pay out?
Thanks so much for all of the info!!
Dave
   / Heat and Air ? #34
I am glad I don't live in OK. Couldn't stand that much variation on the temps (0 - 100+). Can't say much about heat as I never use a heater here. No need for such a thing. I do have a new heat pump that was just installed last year. The original AC unit on this house when it was purchased was a RUDD (stay away from them).
After some serious discussion with a friend in the AC industry, I chose American Standard/Trane. I liked the dual compressor setup they have. One is smaller than the other. The small one kicks in and out to maintain the temp. If the small compressor can't keep up, the second one kicks in.
It has cut my cooling cost almost in half and I can maintain a lower temp in the house (72 degrees).
   / Heat and Air ? #35
I'm curious as how the laws are interpreted in your state.
You mentioned the house was built some time ago, with what I assume is the orignal HVAC system.
"Retrofit" systems now must meet 13 SEER minimum requirements. Assuming that on the one quote that they are only changing the OUTDOOR unit, I can't see how with the existing indoor coil they will meet 13 SEER (no way in **** more like it) with only the outdoor unit (being ARI matchup). You may also have issues going to a "new" outdoor unit with an older coil.
In laymens terms, if you only change the outdoor unit (with the older coil still in place), you may actually only get a 10 SEER rating if your lucky.
Not to mention what metering device is required with the condensing unit.
I'm sure this gentleman explained this to you.
The $3500 quote sounds VERY resonable for the complete changeout (including furnace).
It would be impossible for a company that pays insurance, wages, taxes, overhead, "stands behing thier work"...to meet that price for doing a COMPLETE job.
Keep in mind, it is VERY easy for someone "part time" to give you a GOOd price, it is somthing else trying to get that same person to do service work when you need it the most (particulalry when it's 100F and your A/C isn't working or 20F and your funace isn't working).
   / Heat and Air ?
Thanks again for the feedback. We do have some crazy temperature shifts here, the worst is out in the panhandle (far NW) it can be very very cold in the winter and 110 or more in the summer. I don't know how people do it. Yes, when I had talked to the local guy he did inform me about the cons of just upgrading the outside unit, and I had read about that on the internet also. I am leaning toward the 13 sytem (everythig). I am just waiting for Hunter now. I believe that the savings over the 15 seer would be better spent in new insulation in the attic and other efficiency things.
Thanks again everyone!
Stay Cool /forums/images/graemlins/smile.gif, Dave
   / Heat and Air ? #37
</font><font color="blue" class="small">( Yes, when I had talked to the local guy he did inform me about the cons of just upgrading the outside unit, and I had )</font>
Considering the fact that this "guy"" actually realizes the cons of using the old coil, but still leaves it as an option to "leave it in place", good luck, you may need it.
Angone I know worth doing business with who wants to make sure they have a satisfied customer would rather walk away from a sale than "make a sale" and have a serious potential problem down the road that they (the installer) knew might happen if they did work and "took the easy way out".
I also hope this guy told you that if you use the old coil and they are not "rated" together, you VOIDED (and I'm very familiar with American Standard, my guess is that it is thier "Heritage" series he's selling you) any warranty (sp?) that you may of had with the new condensing unit.
Just make sure you know of all the cons.
   / Heat and Air ? #38
<font color="blue"> </font> The $3500 quote sounds VERY resonable for the complete changeout (including furnace). <font color="blue"> </font>
I was installing goodman & armstrong 10 seer complete swap outs for about that price 2 yrs ago
)</font>
   / Heat and Air ?
Got everything in, I have been checking the forum and trying to figure it out. Air is a GOOD thing. Unit runs great, we just got the electric bill for last month, and it is 2 what it usually is for May! I did not realize it had got so bad.
Thanks for all the help, Dave
   / Heat and Air ? #40
When they replaced my old A/C unit, they replaced the "A" coil along with the outside unit.........he also said the new one would not last nearly as long as my old one did, and I could easily see what he was talking about, the old one weighed twice as much as the new, and you could feel the difference (and see it when he cut the lines) in the old copper........
That said, it cost 1/2 as much to cool my house after we changed it out. at least till the electrical costs went up so much, now we're about back to square one...........
But the house is cool!
We get about the same temps/humidity here as they do in OK..........
Gotta have cool air in the summertime!
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
UNUSED DIGGIT EM15 EXCAVATOR (A54756)
UNUSED DIGGIT EM15...
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
UNUSED LANDHONOR MGB-72-44W 44" MINI GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
