Heat Gun Saves The Day!
   / Heat Gun Saves The Day! #11
DieselPower said:
It was (was being the key word) common practice for all the local fuel distributors in my area to cut their winter blend diesel fuel with kerosene. Seing as most all of them only carry ULSD now they can no longer perform this practice. Adding No. 1 kerosene would lower the cold filter plug point of the fuel while not increasing it's cost. It has all has to be done with additives at the bulk distribution points now.
Another downfall of the ULSD is that it by nature has a higher cold filter plug point. I have seen test results that showed samples taken from the pump had cold filter plug points as high as +7 degree's F. Any good pour point depressant should lower it to around -25 degree's F.
Where I live...#1 diesel fuel and "kerosene" is two totally different critters...and in my Kubota manual it dont say jack squat about using kerosene for fuel!
   / Heat Gun Saves The Day! #12
Heat guns and flamable material = FIRE.
mark
   / Heat Gun Saves The Day! #13
They are not very different. They have overlapping specifications such that one product can be sold as either kerosene or #1 diesel.
   / Heat Gun Saves The Day! #14
mark
Mark, I think (or at least I hope!) that he was talking about an electric heat gun rather than an open flame of any sort:). For situations like this I actually prefer my wife's hair dryer (don't tell) because it does not get quite as hot.
Tim
   / Heat Gun Saves The Day! #15
"Much" different?? No idea. But I did see a "kerosene" stove once filled up with diesel fuel.....smoked like a SOB!!!
   / Heat Gun Saves The Day! #16
Kerosene releases heat when burned, making it useful as a fuel. Its heating value, or heat of combustion, is around 18,500 Btu/lb, or 43.1 MJ/kg, making it similar to that of diesel.
Kerosene is obtained from the fractional distillation of petroleum at 150 °C and 275 °C (carbon chains from the C12 to C15 range).
Typically, kerosene directly distilled from crude oil requires some treatment, either in a Merox unit or a hydrotreater, to reduce its sulfur content and its corrosiveness. Kerosene can also be produced by a hydrocracker, which is used to upgrade the parts of crude oil that would otherwise only be good for fuel oil.
At one time it was widely used in kerosene lamps and lanterns. Now it is mainly used in fuel for jet engines (more technically Avtur, Jet-A, Jet-A1, Jet-B, JP-4, JP-5, JP-7 or JP-8). A form of kerosene known as RP-1 is burned with liquid oxygen as rocket fuel. These fuel grade kerosenes meet specifications as to smoke points and freeze points.
Diesel is produced from petroleum, and is sometimes called petrodiesel when there is a need to distinguish it from diesel obtained from other sources such as biodiesel. It is a hydrocarbon mixture, obtained in the fractional distillation of crude oil between 200 °C and 350 °C at atmospheric pressure.
Petroleum derived diesel is composed of about 75% saturated hydrocarbons (primarily paraffins including n, iso, and cycloparaffins), and 25% aromatic hydrocarbons (including naphthalenes and alkylbenzenes).[5] The average chemical formula for common diesel fuel is C12H26, ranging from approx. C10H22 to C15H32.
The density of diesel is about 850 grams per liter. When burnt, diesel typically releases about 40.9 megajoules (MJ) per liter.
In short, they are similar but are by no means the same. You would not want to run full strength kerosene in your modern diesel engine, it wouldn't last long. However, when used in ratio's of up to about 1/4 kerosene to "cut" diesel fuel it has no real adverse effects.
   / Heat Gun Saves The Day! #17
Dont tell me you typed all of that from memory...lol...:D
   / Heat Gun Saves The Day! #18
Memory, what memory. I Wikied most of it, my internet memory bank. :D
   / Heat Gun Saves The Day! #19
On #1 diesel?
I used to run Jet-A, #1, or kerosene interchangeably in an indoor kerosene heater. Couldn't tell the difference.
We used to haul Jet-A and #1 out of an Amoco distribution terminal, and both came out of the same tank. The only difference was what was on the Bill of Lading. Although they did not have "kerosene" available as a product, a chemist at that terminal explained to me about the overlapping specs of #1D, kerosene, and Jet-A and that one product could be refined that could be within the specs of all three. Once I heard that, I quit buying kerosene for the heater and used waste amounts of JP-4 and #1D that was left on the truck at the end of the day.
   / Heat Gun Saves The Day! #20
How come you don't have a block heater up there in the great white north. :)
2007 JLG 600S SKYPOWER TELESCOPIC MANLIFT (A51246)
2007 JLG 600S...
(5) 55 GALLON POLY DRUMS (A51248)
(5) 55 GALLON POLY...
(1) UNUSED 5200# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 5200#...
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
SHOP VAC 6.5HP WET/DRY VAC (A51248)
SHOP VAC 6.5HP...
