DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,579
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
I have two sources of heat. One is a 140,000 btu waste oil furnace, and the other is a wood/coal stove. Haven't gotten the WOF set up in the new shop yet, so just heating with the coal stove. The furnace is one of next years projects.
In the shop at the other farm, the WOF kept it nice and toatsy in my 32' X 36' shop very easy. I could heat all winter on between 350 and 400 gallons of used oil. It does need the heated nozzle mechanism cleaned about every 750 hrs. of burn time, which usually falls about the end of Jan. Takes about an hour to do, which seems like forever if it's close to zero outside. That's why I put in the coal stove, so as to save on oil, and a source of heat when servicing it.
I learned long before using the WOF, and when using a regular oil furnace to heat the shop, the big secret is to keep the concrete floor fairly warm. So when not in the shop, I set the thermostat down to about 45º -50º. Otherwise, you're only warm from the knees up until that floor gets warm.
I wouldn't be too concerned with creosote buildup if you use dry wood, ideally cut 2 years ahead. Coal is fairly reasonable here in price. I can get it from the mine for $75.00 per ton, and can hand pick for that price. I worked out there a lot last winter, and although the temps weren't all that severe, probably went through 1-1/2 tons, and the shop is not completely insulated, and sided, even yet today. It kept the shop at a comfy working temp of 60º to 65º, and not firing it real hard, just keeping the optimum burn temps on the stove at around 500º.
