Heavy Duty Pickup Shootout
   / Heavy Duty Pickup Shootout #11
I just read this from front to back. They all seem pretty close. The biggest difference was features which Dodge seemed to lack over the GM and Ford offerings.
The biggest area where one truck shined in my eyes is the speed and time for the hill climbs on the diesel trucks. Ford had a real advantage there which is what I do hauling heavy loads up and down serious steep grades many times from a dead stop or at low speeds.
I will give GM credit on its brakes. The ones on my 05 Dmax sucked compared to the Ford diesels I have owned. It seems they now have best in class breaking in the 1 ton diesel segment. Another area they improved on was the crummy interiors. Looks like they may have a winner. While they have done some things right I will not be buying any GM products for all they have done wrong.
Cant wait to see how Dodge comes back at the competition. While I am a Ford HD guy I would buy a Dodge diesel if they could make a product that beat them out.
At the end of the day they are all very close. Some do this better than others but each have a strong point. My dream truck is still a F-350 SRW 4x4 with a Cummins that makes 400HP and 800 FT LB TRQ with a 6 speed Torq-Shift tranny. I guess I will have to hold my breath.
Chris
When you get into the 1 ton duallys on the 7% & 16%, the GM won. 12,000lb and accelerating at over 53.9 MPH vs 51.9 on the 7% as an example. The .1 second difference in time would be completely gone on a longer grade. It had already cut the gap from .7 to .1 seconds over the run.
   / Heavy Duty Pickup Shootout #12
Wonder what difference decimals of a second make out in the working world.:D
   / Heavy Duty Pickup Shootout #13
What really surprised me is how much headway GM has made. They are now on par with Ford on many levels. I applaud them for that. Still would not buy one but give credit where its due.
The main thing Dodge needs to work on is getting the GVWR up and the GCWR up also. They are 7,000# behind the competition in some cases. I guess this will all come with the increase in HP and TQ along with a new chassis they are surely working on so they can compete.
Chris
   / Heavy Duty Pickup Shootout #14
No they don't need to increase the GVWR/GCWR. 13k GVWR / 26K GCWR is more than enough for a 1-ton pickup truck. If you really want a truck to tow/haul more then get a class 5, 6, or 7 truck. The RAM has a max tow capacity of 17k lbs. Anything over that and you are pushing that 26k GCWR limit which requires a CDL...
Also, looking at the test I don't think they need to up the power either since they were within an arm's distance of the other two yet cost $8k less and have a more reliable and durable engine. With the new 8-speed auto they are likely to add to the Cummins diesel for 2011, the fuel mileage should jump way beyond the other two as well.
   / Heavy Duty Pickup Shootout #15
Both GM and Ford are over the 26K point. GM for the 3500 rates it at 21,700lbs of towing capacity. That and truck weight is way over 26K.
   / Heavy Duty Pickup Shootout #17
I am not going to get into the CDL thing. Its been explained many times.
The simple fact is 17K is way behind the competition unless you are brand loyal. I buy what is the the best most capable truck. You may not believe that but the facts are I have had everything but a Toyota in the last 5 years but have had one of them also and it was great.
Now a 8 speed tranny will be interesting. I would be the first one on the lot to test drive a new Dodge with a 8 speed auto and a Cummins that made the power the others are along with a GVWR and a GCWR that was close to the competition.
Chris
   / Heavy Duty Pickup Shootout #19
The main thing Dodge needs to work on is getting the GVWR up and the GCWR up also. They are 7,000# behind the competition in some cases. Chris
dude this has to be nothing but "on paper numbers". There really cant be that much difference in frame designs, curb weights, wheel bases, brakes etc...
just like the HP wars... towing number wars.... they will just "invent" a new larger number to keep up with mr jones across the street.
oddly enough our new 2010 heavy rescue (some sort of class 4/5 chassis) for our FD with a 18K curb weight with tools and 5 personal (per the grain scale) has the same cummings engine and 6spd trans as in the LT pickups.
<cough> in IL up to 26,000 lbs class B non-cdl <cough>
   / Heavy Duty Pickup Shootout #20
well heck yeah GM wins, if they didn't I would be upset after the govenment invested $billions in R&D for them. ha ha
before you start I own a chevy right now, but probably won't again. Love the truck hate the way the company was ran.
2011 MACK CHU (PINNACLE) (A58214)
2011 MACK CHU...
2010 Toro Groundsmaster 3500-D Sidewinder 3 Deck Rotary Commercial Mower (A56857)
2010 Toro...
205196 (A52706)
205196 (A52706)
1764 (A58375)
1764 (A58375)
202475 (A54757)
202475 (A54757)
1682 (A58375)
1682 (A58375)
