Heavy FEL work (3500lbs)
   / Heavy FEL work (3500lbs) #21
Do you own or run a skidloader?
I own a mid size Deere and can handle that pallet, it would be a cake walk for a bigger Deere.
You got to keep in mind how these machine are rated before you can comment on safe operating range.
Yes I do, a JD 325 (2500# ROC). Yes, I do understand how they are rated: about half of tipping load. Sure, you can exceed it, but a ss is a short wheel base. On nice flat concrete, you're probably safe handling higher than rated capacity. But get on a bit of an incline or a bump, and they aren't that stable. Can they do it? Yes. "Cake walk"? No.
Ken
   / Heavy FEL work (3500lbs) #22
Ken
Ken, ROC on a SS is 33% of tipping load. Handling that pallet at tailgate height is a Cake Walk. :thumbsup:
   / Heavy FEL work (3500lbs) #23
You are confusing skid steers (SS) with compact track loaders (CTL).
Typically, CTL's are rated a 1/3rd of tipping capacity. SS's are rated at 1/2.
Usually CTL's have higher tipping loads because their track idlers provide support further forward than a rubber tired SS. CTL's tend to be more stable since they have "more rubber on the ground".
Ken
   / Heavy FEL work (3500lbs) #24
Usually CTL's have higher tipping loads because their track idlers provide support further forward that a rubber tired SS. CTL's tend to be more stable since they have "more rubber on the ground".
Ken
You're right.:eek:
   / Heavy FEL work (3500lbs) #25
I have a Mahindra 7520 rated at 3900 to full height at the pins. There is a gauge added to show pump pressure. The ML275 loader has a SS QA mount and a SS Tilt Tatch on it, which together shift the load 6" or so forward from standard, and add at least 400lbs. I have a 4000# rated fork attachment that has 48" tines. With this on that setup I have worked with 2500# concrete block distibuted evenly on tine length. Curl is at the limit, registering 2500psi. Lift uses about 2000psi. The tractor handles fine with a 1200lb counterweight - a flail centered about 30" behind the 3ph lift eyes. [I dont know whether I had put water in the tires before this or not.]
larry
2016 John Deere 326E (A47477)
2016 John Deere...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
Hose Reel (A53424)
Hose Reel (A53424)
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2015 Ford F-150 (A53422)
2015 Ford F-150...
