rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,583
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Ok, still having issues on my 52 8n side distributer 12v tractor. Waiting on key switch, hung up in houston. Usps. Enough said on that. I jumped the switch out and still didnt have very good fire. Changed out coil and i started right up. Alrighty then. Ran great for two days but this morning wont start. It was 35 degrees outside. Waited till after lunch, 45 degrees outside. Started right up. What can i check or adjust or change to fix a tractor that wont start in cold weather ?
Ok. So on one hand we know that it can run fine with what it has.... and on the other hand we know that it doesn't always do so. That could be anything, but it tends to be just what you are thinking - it's probably electrical.
Did anything else change except the temperature? Anything at all? Did you drive it around? Add fuel? Check the spark? Bend the spark cables?? Pull the rotor?
We're needing to find another clue here....
rScotty
BTW,
The reason we usually replace all the old battery & coil electrical tuneup parts when we do a tune-up is because they can wear out in a fashion that is difficult to test. Or irratic. That is, they end up neither good nor bad....but somewhere inbetween.
That's because when electrical components are new, no matter what their job is, they they are generally designed to be a combination of parts that conduct electricity and and parts that don't. When they age, that line becomes blurred. Especially with the older stuff that used cotton fiber based insulation and hard plastics. Those old parts just didn't last as well as modern stuff. When we say "didn't last as well as modern stuff", what we mean is that those old electrical components get "internally leaky" from unwanted conduction paths.
It's one of the few times old mechanics will admit that newer is often better.
