Hello from Mississippi / '73 MF135
   / Hello from Mississippi / '73 MF135 #1
lugnut1009
Vicksburg, MS
1973 Massey Ferguson 135 Diesel
Just joined today. I have a 1973 Massey Ferguson 135 Diesel that is in pretty sad shape. It runs fine, smokes under load (kinda expected I guess), and has a few leaks. But for about $1000 I think I did pretty good. I've had it for a little over a year and haven't done much to it yet besides replace the seat and just run it. I have the rear tire off right now trying to revive the brakes.
Just wanted to introduce myself properly. Hopefully I will make this thread a little longer over time updating with pics and questions. Thanks in advance for any help with it. :thumbsup:
   / Hello from Mississippi / '73 MF135 #3
:welcome: 1967 MF 135 Perkins Diesel
   / Hello from Mississippi / '73 MF135 #4
Hey back from Lena, Ms!
   / Hello from Mississippi / '73 MF135 #5
Hello, back at you from southwest ms. 1970 massey 135 perkins gas.
   / Hello from Mississippi / '73 MF135 #6
Welcome Mitch. Alot of 135 lovers here. Alot of knowledgable 135 owners here. Take care. -robert
Thanks, and it's probably a good thing, looks like I'll need my share of help on this one.
   / Hello from Mississippi / '73 MF135 #8
Alot of helpful folk here Mitch. We've got a pretty active area with alot of 135 talk going on. A few restorations and lots of repair talk. The MF Classic/Vintage sub forum is relatively new with alot of activity. Take care. -robert
Massey Ferguson Classic/Vintage
   / Hello from Mississippi / '73 MF135 #9
Welcome to TBN:thumbsup:
   / Hello from Mississippi / '73 MF135 #10
I bought a MF 135 and want to use the auxillary hydralics. My valve is under the seat and has a handle which can be rotated from forwards on the tractor and moved 180 degrees to pointing backwards.
I am unsure of which way to move the handle to use the auxillary. I have moved this in conjunction with moving the 3 point handles.
When I attached my log splitter to it. Nothing seems to work. When I rotate the handle straight up and move 3 point handles back, nothing happens. I can walk back and lift the splitter and it will raise.
Any Ideas? I have not found the combination to make the 3 point or the auxillary valves work. I realize that both of these can't work at the same time and that is no problem. I would just be happy if either one worked seperately.
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A55973)
2022 Power Screen...
