hello miner here
   / hello miner here #11
Im betting to much was let out... simple check of the gages will be able to tell whats happening... Havnt had much issues out of those ACs... its a much better system than any of their others
   / hello miner here #12
That s why I question the dealers. Gauges are only a diagnostic tool. Without looking up the spec I'm guessing the system holds 2 to 3 lbs. Did they evacuate the system and measure? I'm guessing not. The dealer that said it was high probably only saw a high reading and assumed there was too much. Thats bad because high psi can be caused by a bad expansion valve. Connecting to both high and low sides and making sure the psi is equal would be my first step. Then start the engine,observe the readings. Now shut it all off. You should see the pressures begin to equalize.If not the expansion valve may be bad or blocked. This leads me back to say, make sure the dealer you have is HVAC certified. :cold:
   / hello miner here
Thank you Jabonee I'll check and see
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
16ft T/A Flatbed Equipment Trailer (A50323)
16ft T/A Flatbed...
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
