Help! 2001 Kabota M4900SD-F
   / Help! 2001 Kabota M4900SD-F #1
Jakie
South Texas
2001 Kubota/M4900 DT
I just found this web site and the message board. What a great site. I need help. New tractor guy, thinking of purchasing a 2001 M4900SD-F, 4 whl drive, front loader with 287 3pt 7' bush hog shreader. Has 1 yr power train warranty left. Local dealer asking $19,500. Does this seem in ball park. Any experience with this model as to problems to expect and is the 49 horse good to go, underpowered? Thanks
   / Help! 2001 Kabota M4900SD-F #2
Kubota
How many hours? It must be 1 year old since the warranty on the drive system is 2 years if I recall correctly. 200 to 300 hundred would be a typical number of hours for a moderately used tractor one year old. Check tractorsmart.com or another dealer like Carvers for the retail price. You will also find some great info about the tractors and options available.
   / Help! 2001 Kabota M4900SD-F #3
</font><font color="blue" class="small">( Kabota )</font>
Now Mark... isn't that the Chinese clone of Kubota...? /forums/images/graemlins/tongue.gif
...If so... it should be a lot cheaper... /forums/images/graemlins/wink.gif
   / Help! 2001 Kabota M4900SD-F #4
The M series are among the larger Kubota tractors - 49 HP is pretty strong for a CUT. With the loader and rotary cutter the price isn't bad, but you do want to check out the number of hours.
I guess the big question is what you're planning to use it for. If you're mowing just a few acres that may be a bigger tractor than you need. If you've got a fair amount of property it might be too small, but without knowing it is hard to say.
   / Help! 2001 Kabota M4900SD-F #5
GLAD U FOUND THE FORUM! AND THE PRICE U QUOTED SEEMS OK. but u don't tell us your needs and acreage? may be too much tractor or not enough. need to fill out your bio a little, gives the guys AND gals a better idea of your needs.
WELCOME ABOARD
   / Help! 2001 Kabota M4900SD-F #6
Welcome Jakie,
I've got a 2001 M4900 but mine is 2wd. I have been extremely pleased with this tractor. It has plenty of power for mowing (I use a 6' cutter), plowing, box blade work,etc.
I can't help you on the price but that sounds about right if the hours are reasonable. I gave $16000. for mine without a fel.
Good Luck!
TBone
Re: Help! 2001 Kubota M4900SD-F OOPs on Spelling
</font><font color="blue" class="small">( I just found this web site and the message board. What a great site. I need help. New tractor guy, thinking of purchasing a 2001 M4900SD-F, 4 whl drive, front loader with 287 3pt 7' bush hog shreader. Has 1 yr power train warranty left. Local dealer asking $19,500. Does this seem in ball park. Any experience with this model as to problems to expect and is the 49 horse good to go, underpowered? I have 65 acres of grass for a small cow/calf operation. Will be doing mostly mowing and some dirt/drainage work, minimal plowing. Picking up a few 6 x 5 round bails, etc. Thanks )</font>
Hey thanks for the reply. It has 150hrs. Be using it on 65 acres and a small cow calf operation. Few 6 x 5 round bails and mostly mowing and some plowing. Great site.
Opps, not so good a spelling or computering. Thanks for the feed back. It has 150 hrs and I'll be using it on 65 acres in S. Texas cow/calf, weekend work place. Great forum?
New to the use of forums. I'll try to find the bio section and fill it out. Not good a spelling chinese tractor. I will be using it on 65 acres in a small cow calf operation. Mostly mowing and round bales. Great idea this forum. Sure glad I found this site.
   / Help! 2001 Kabota M4900SD-F #11
If this is going to be your only tractor I'd say that's too small of a tractor. What else are you going to want to do?
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
2003 McCormick XTX 185 XtraSpeed Tractor (A61307)
2003 McCormick XTX...
(4) UNUSED FORERUNNER 10-16.5 SKID STEER TIRES (A60430)
(4) UNUSED...
2021 CATERPILLAR GP30N STRAIGHT MAST FORKLIFT (A60429)
2021 CATERPILLAR...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
