Help -broke bead
   / Help -broke bead #11
It will also help if you can take the valve stem out. That will give you more air flow to help seat the bead. Good luck.
I think you mean valve core not valve stem. And yes it does make a big difference.
   / Help -broke bead #12
Sorry about that yep should have said core not stem.:eek: Kinda of hard to put air in if you take the stem out
   / Help -broke bead #13
Glad to see that video as I couldn't remember how to ignite the either without getting my hand too close.
That sticky stuff that you coat the rim with is called "RimTite". Any auto parts store should have it. Great stuff....
   / Help -broke bead
Well thanks for all the reply's.
When I finally got around to it it virtually reseated itself (hot day, it was out in the sun all day) so I slimed it and it seems to be sitting ok.
   / Help -broke bead #15
the not safe way but works great method is spray a little starting fluid in the tire and have a match on the end of long handle and it will ignite and expand so fast it will seat your tire on the rim.........again.......prolly not real safe!!!!!!!!
Gee...I was gonna say the same thing...only as a joke:D People really do that?:eek:
   / Help -broke bead #16
I've seen (on TV) the can of ether used as a torch to lite off the tire! Not that I recommend doing this.............
2010 Kubota L3400 (A50120)
2010 Kubota L3400...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
Case International 585 Tractor (RUNS) (A50774)
Case International...
2013 Chevy 3500 Mechanic Body (A47384)
2013 Chevy 3500...
