Help Cut TV cable with ditchwitch what to do??
   / Help Cut TV cable with ditchwitch what to do?? #11
Been there done that. Was tilling up my yard, my daughter told me the cable went out....the light bulb went on and I went to the back yard and sure enoug there was a pretty bright orange cable slighty chewed in two....called the cable guy and they were there in the morning to fix it....serves them right laying a cable three inches below the surface of the ground /forums/images/graemlins/shocked.gif.
   / Help Cut TV cable with ditchwitch what to do?? #12
When the repair of underground cable or wiring is completed and tested for proper function it then needs to be sealed in water proof epoxy. Kits are available with a clear plastic mold to clamp around the repaired area, then the included epoxy is mixed and poured into the mold. After it sets up in a few minutes the cable is ready to be buried again. If the repair is done properly the splice should be reliable for the life of the cable.
I would leave this repair to the professionals. They will probably do the repair and seal it with the epoxy or replace the cable completely.
   / Help Cut TV cable with ditchwitch what to do?? #13
I needed my cable outlet moved and made longer but the cable company said it would be a couple days and $100 for the service call.
I went to Nations where I'd seen several cable trucks parked during lunch time and offered the first guy I saw $40 cash to do it right now. He said sure, and did a first rate job.
Before you call the cable company, ask around and see if anybody you know has a friend working for the cable company. You might get it done for free.
Good luck,
Eddie
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
New Idea Manure Spreader (A50515)
New Idea Manure...
TRUCK FLATBED (A52472)
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2001 John Deere 670C Motor Grader (RIDE AND DRIVE) (VERY NICE) (A50774)
2001 John Deere...
