Help! Diesel fuel in my rtv500!!!
   / Help! Diesel fuel in my rtv500!!! #11
A little diesel will only serve to be a good upper cylinder lubricant (valve stems). It would take a long time to foul the plugs and would not contaminate your crankcase oil whatsoever. Pure diesel will not be atomized by a carburetor the same as gasoline, but probably up to a 25% mixture would only produce excessive smoke like a 2-cycle engine. I would not even worry about your fuel filter since its job is to remove solids and trash. I can remember gasoline engines produced during WWII that could run pure kerosene.
I'm not old enough to have been around during WWII,
but several of those tractors and cars were still around when I was a kid and some still exist today.
I was born at the begining of the war and my wife was born at the end of it .
   / Help! Diesel fuel in my rtv500!!! #12
Just be glad that it was not the other way around, diesel and they mistakenly put gas in it.:D
   / Help! Diesel fuel in my rtv500!!! #14
Back in the day, many ignition engines were designed with two fuel tanks. You would start the engine and shut it off on gasoline and run it on diesel. They ran kinda smoky and stinky, but it is not the disaster some might have you believe.
Had a cousin that had a dozer like that.
2015 MACK CXU613 (A52472)
2015 MACK CXU613...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52748)
2020 New Holland...
Super Material Lift MH1000 (A52748)
Super Material...
FAKE (A52472)
FAKE (A52472)
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
