Help for Iseki TL 2500
   / Help for Iseki TL 2500
According to the owner's manual pg. 5:
'D. AIR CLEANER LIGHT
Indicates if air cleaner is clogged. With engine running check light by pushing check button "U". If light remains on or glows after button is released, stop engine. Refer to maintenance section for care of air cleaner.'
"D" is from figure 3 and points to the picture with the arrow and particles
"U" is from the same figure and points to the button underneath the light switch (blinker on my tractor, headlights in figure 3) on the left side of the panel.
Hope that helps.
I have owners manual and I don't know what is "U" and "D" but I will make picture of the lighting button, as I said I cleaned the air filter, and the button lighting only during the button is pushed, when I release them it stops lighting.
I will post links for pictures in Monday.
Thank you for the time.
Cheers: Peter
   / Help for Iseki TL 2500 #12
The icon described is indeed the airfilter clog indicator.
This is a vacuum switch placed between filter and engine. When the filter clogs the vacuum pressure rises and activates the switch.
I do not see otherwise on my TL, nor do i get the explanation from the manual.
The switch is a simple bridge to check the functioning of the indicator light itself. (put 12v directly to the lamp)
I read the text of the manual as if the switch is activating the vacuum switch and when it doesnt switch off the filter is clogged. That is not the case in reality.
   / Help for Iseki TL 2500 #14
I replaced my ignition switch....bought a new key switch from a Kubota dealer eliminated the old key switch and only need the one...the old glowplug and starter switch had only 4 terminals this new key switch from Kubota has 5 one for accesories works great i hope this info is usefull....Ampa
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A56138)
2020 INTERNATIONAL...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
