HELP: G2460 starts to stall when hitting bumps
   / HELP: G2460 starts to stall when hitting bumps #1
Evil the Weasel
Platinum Member
Central NY
Kubota B2620
I hope to soon own a compact utility tractor, but for now I have this 3 cyl 24hp Kubota G2460 that has served me well. The problem I'm having right now is that it starts to stall/sputter when bouncing over rough terrain. I have to stop and let it recover and I can smell gas during these sputtering events. They are happening more and more frequently also. My brother thinks it's the seat switch, but I have no idea. It happens whether the mower is engaged or not. Anybody have any ideas what is going wrong? I'd rather not take it to the shop because I need the machine constantly. Thanks in advance for your advice.
   / HELP: G2460 starts to stall when hitting bumps #2
I'm with your brother. Sounds like the seat switch to me. A jumper could confirm that and keep you in business while a new switch is being ordered.
   / HELP: G2460 starts to stall when hitting bumps #3
Rough ground will help bring water thru the system that might have been sitting in the bottom of the tank or in a filter or even in the carb!
   / HELP: G2460 starts to stall when hitting bumps #4
I noticed the same issue on my BX if I was using the FEL without the BH attached. It ended up being the seat and me was being bounced around just enough to make the seat safety switch kick in. I wish I could disable it temporarily to avoid the problem.
   / HELP: G2460 starts to stall when hitting bumps #5
Sounds like you need to have your seat belt fastened.
Same thing happens to me comming down a hill if I'm not belted in.
   / HELP: G2460 starts to stall when hitting bumps #6
I defeated my seat switch. I know, I know someone here will smack for this, but the danger of stalling the engine so many times outweighs its purpose.
71057 (A49346)
71057 (A49346)
2022 Continental 16' Enclosed Trailer with ramps (A49461)
2022 Continental...
MEGGER EZ THUMP (A50854)
MEGGER EZ THUMP...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
1240 (A50490)
1240 (A50490)
