Help! GC1705 Hydraulics out
   / Help! GC1705 Hydraulics out #21
My tractor has a dip stick, both in the tranny and on the seat:D
BMW motorcycles uses a similar style window and the have also had some issues with these being blown out. I believe they have now changed designs so that these pass in from the inside and there is a lip on them to prevent them from being pushed out.
Update:
Dealer ordered new sight glass and "glued it" in. They are letting it sit 24 hours to set, then will pull suction filter and check if, if that looks ok they'll fill it back up and test all pressures as advised by Agco and we'll go from there.... If all they do is refill/test I'm REALLY hoping they'll extend warranty or something because I'm sitting at 200 hours and fearful I'll have issues (out of warranty) down the road.....
The gluing of the sight glass also has me worried for long-term reliability. Wonder if we could get something machined out of metal that might work/fit better? Plastic to metal seems to be asking for trouble IMO....
   / Help! GC1705 Hydraulics out #23
Could you find out what they used to glue it in?
I doubt if any damage was done but man, that sure seems like a bad set up to me. You stated that you were vigilant about checking the fluid level so I assume there's a good chance that there was no leaking before it popped out.
Yep - when I first got the tractor I had a leak, took it back to the dealer and it turned out they had overfilled it. So I've always watched it really careful since. He did mention they were going to have him check the vent also to ensure it wasn't some sort of pressure that forced it out... Will ask what they glued it in with when I get it back. I'll likely also order a spare sight glass juuuuust in case.
   / Help! GC1705 Hydraulics out #25
wow the things we as paying customers have to deal with. I would get it in writing on what was the failure was and how the factory designed it/installed it! This is a huge defect from the factory. Then in writing i would have them state what did they do specifically to fix it.
   / Help! GC1705 Hydraulics out #26
The fill tube cap is the breather for our tractors (GC17XX). Looking at mine, it only has a small hole on the side of the cap to vent pressure as the temp rises and falls in the transmission. It works just like a plastic fuel can setting in the sun. When it gets hot, the air inside expands. That pressure is vented out of the cap. I don't know about the groups tractors, but my fill/vent cap is in very tight. Tight enough, if the vent hole gets clogged, it is possible the pressure could push the sight glass out. I have seen clogged vents blow seals many times. It is going out the weakest link. I am not overly worried, because I have never heard of this before, but I will ensure my vent is cleaned each service.
So the verdict is in: They replaced the sight glass, said all pressures from the hydrostat are within spec, and it's moving about just fine. So a refill is all they've done. Haven't heard back from the rep on anything else warranty wise yet.
While it was there I had them do the 250 hour service, and also had them do the mower deck lock fix. The guy wasn't sure if they'd pay for that or not. There are apparently 2 new parts for the mower deck that will keep it locked in lock mode. I took the tractor in when almost new for this, so IMO it should be free as thats how the thing should operate, but I don't know what the rep told the mechanic (he's off today). Should hopefully get it back tomorrow (they were waiting on a fuel filter).
I'm hoping they'll do something warranty wise because I'm pretty nervous about things after having operated it low, then pretty much empty if even for a short time due to a manufacturing defect.
I'm also thinking that once I'm out of warranty, I'll replace the sight glass with a metal freeze plug and fashion some kind of dipstick to check fluid. I don't trust plastic glued into metal.
C
   / Help! GC1705 Hydraulics out #28
IMO, pressure building in the case, even if the vent was plugged, should have popped the fill cap off before popping the sight glass out.
   / Help! GC1705 Hydraulics out #29
I disagree. My fill cap is super tight. I would guess 20lbs of pressure to get it out. It is probably different for each of us.
   / Help! GC1705 Hydraulics out #30
C
How will you keep up with your fluid level?
2007 Deere 650J LGP (A53314)
2007 Deere 650J...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
2013 Freightliner M2 106 Stellar 12621 6-Ton Mechanics Crane Truck (A55852)
2013 Freightliner...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
40ft 2-Door Shipping Container (A55851)
40ft 2-Door...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
