ishiboo
Platinum Member
I rented a John Deere 35C mini excavator, and while digging up a stump (not even using the thumb) the thumb's cylinder rod snapped, dumping oil all over. I thought it was very odd that it snapped when I was digging up little 1" roots and not even using it, but the company was nice and ordered the parts and volunteered to do the labor.
I took the cylinder to them, strapped the thumb to the dipper stick and went back to work finishing the tree. (It's only a 2.5" tree and not much was left.) As I dug I saw something shiny - the piston end of the rod!
My theory is that the piston actually turned in the bore, over the 3200 hours on the machine, and finally the rod fell out. As it came down it over-extended, and when I curled the bucket bent and then snapped the rod off. All but the end 1/4" of threads on the rod are mint. I don't see any other way I could have broken a rod and caused it to safely unscrew itself from the piston! I guess this would have happened to whoever used the machine next.
Am I wrong or was this not my fault? What else would have done it? The rod end is just a simple thread and there does not seem to be anything besides the threads and however the rod fits into the piston that would have kept the piston from turning in the cylinder bore.
