Help!!! Hydrostatic Fluid on Kubota 7200HST
   / Help!!! Hydrostatic Fluid on Kubota 7200HST #1
biplane
Please help - I'm clueless. My hydrostatic transmission started slipping yesterday on my Kubota 7200 HST. I checked the fluid and it's so milky I could pour it on my Cheerios. I don't have a manual for it, but I thought I would change fluid and see if that fixed the slipping problem. I went to the dealer today and bought 4 gallons of oil, and a filter. They pointed out 3 drain plugs on a similar tractor. I found 1 on each side of the rear axle and 1 near the mid PTO. Out came about 2 gallons of milk. Are those the only plugs??? Is the lubrication in the front of the tractor a separate system? If not, where do I find the drains on the front?
I changed the filter, which is mounted vertically and inverted under the panel on top of the transmission. Now, and this shows my ignorance, where do you add oil? There is a 1/2" bolt right next to the filter, but I can't image I'm supposed to pour 4 gallons of oil into that bolt hole.
Please help as I need to get this tractor back up soon!
Thanks!!!!
   / Help!!! Hydrostatic Fluid on Kubota 7200HST #2
Sounds like you have some major water contamination in your oil. If it's as bad as you say I would probably drain and fill as you planed on, run the unit for a while and then drain and refill again. You need to flush as much water out of the system as possible. Hopefully not to much damage has been done. One suggestion I would make is to use a UTF oil that has a good water demulsability rating. This type of oil will let the water seperate and sink to the bottom of the sump where it can be drained.
Thank you. I'll plan to run it for awhile and then drain/fill again.
Can anyone give me further information about my questions? How many drain plugs and where? Where is the fill point?
Thanks!
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2019 Ford Explorer AWD SUV (A55758)
2019 Ford Explorer...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2016 John Deere Gator 825i 4x4 Utility Cart (A55787)
2016 John Deere...
Skid Hydraulic Hose Fittings (A50775)
Skid Hydraulic...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
