HELP john deere 3720 operates wont drive error code 12
   / HELP john deere 3720 operates wont drive error code 12 #1
Confused2015
Louisville ky
2730 john deere
I have 2730 auto st john deere when operating it it will stop and will not move everything else will work fine gives a error code 12 I have replaced sensor on throttle pedal and found orange wire 673 had nick in wire which was rubbing throttle pedal fixed the wire. pulled connectors apart make sure theywasn't dirty still getting a error code 12. wondering do I need to calibrate something or look at replacing a another sensor any advise would be greatly appreciated
SAND SEPARATOR (A47001)
SAND SEPARATOR...
3/4 TON PICKUP (A45336)
3/4 TON PICKUP...
Avant 420E (A42021)
Avant 420E (A42021)
2015 PETERBILT 367 TRI AXLE HEAVY HUAL (A45677)
2015 PETERBILT 367...
2013 PETERBILT 386 (A47001)
2013 PETERBILT 386...
2011 FORD F-450 (A47001)
2011 FORD F-450...
