HELP! Major storm coming and block heater not working!
   / HELP! Major storm coming and block heater not working! #1
massey184ferguson
Atlantic Canada
Massey Ferguson 184-4
Tractor has no glow plugs and yes i'm an idiot for not checking the block heater. Tried it out about 1 month ago and worked fine. I could always hear it humming and today it was about -10 C and I plugged it in for two hours. It did not humm and it was hard to get turned over. It eventually went from compression. Hoping it won't let me down after tomorrows storm. I used to be able to plug it in for 15 minutes and it would fire right up. I guess I'll have to replace the element? Any tips? Is this an easy job to tackle? Thanks guys
   / HELP! Major storm coming and block heater not working! #2
You could always do it the old fashion way and drain the oil and take it in the house overnight.
   / HELP! Major storm coming and block heater not working! #3
Put an electric frying pan under the block, keep it warm.
   / HELP! Major storm coming and block heater not working! #4
Throw a tarp over the tractor and put a small electric heater under it.:thumbsup:
   / HELP! Major storm coming and block heater not working! #5
You could always leave it running all night.
   / HELP! Major storm coming and block heater not working! #6
1) Check coolant level, if you haven't recently.
2) If you have an ohmeter, check the resistance at the BH itself. Should be relatively low, between the element terminals (there should be a 3'rd terminal for ground). I'm gonna go with really course #'s here, and say less than 100 ohms is what you are looking for, across the element terminals. Actual resistance is going to vary in proportion to the rated wattage. (I'm assuming you can disconnect the power cable, at the BH to probe).
3) If you see element resistance at the BH, then check that the same resistance appears on the 2 blades of the final plug. Sometimes it is just the end, final plug that gets a broken internal wire, near the connector.
Lacking a DMM, plug in the cord as you normally would, and slowly flex the cable near the plug, while listening for your normal BH noise to start.
Rgds, D.
   / HELP! Major storm coming and block heater not working! #7
they make magnetic block heaters use to put them on my backhoe 1 on oil pan 1on trans make sure you have a 20 amp circuit or on 2 seperate circuits
   / HELP! Major storm coming and block heater not working! #8
I went through n incredible cold spell about 30 years ago in the north and here's how I beat it. I brought the battery in the house and charged it. Then drained the oil out and put the new bottles of oil in warm water. Come time to start I put the very warm oil in, plopped in the charged and warm battery and it was off to the races. It started immediately.
Then I went about and started it every four hours for two days. Let it warm up for maybe 20 minutes. I don't ever want to be that cold again.
   / HELP! Major storm coming and block heater not working! #9
Don't overlook the obvious, check the circuit breaker in the service panel. Test the outlet with a power tool.
   / HELP! Major storm coming and block heater not working! #10
For a short term solution.......
I have heard people using a hand held heat gun in the air intake for a minute or two to preheat before turning the motor over.... And keeping it there as the engine turns and starts....
I have used this method to help start ATVs and other small engines....
Good luck....
Peterbilt 377 Semi-Truck (A55315)
Peterbilt 377...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
Year: 2015 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 137,900 Plate: Body Type: 4 (A56858)
Year: 2015 Make...
UNUSED CAPTOK BC63-60" HYD BRUSH CUTTER (A57193)
UNUSED CAPTOK...
Year: 2019 Make: Dodge Model: Charger Vehicle Type: Passenger Car Mileage: 118,095 Plate: Body Ty... (A56859)
Year: 2019 Make...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
