newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,151
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
YOU are obviously from a northern climate<snip>
Finally, if you haven't thought about it, I recommend at least a nominal layer of insulation installed under the metal with a vapor barrier between the insulation and the inside of the barn, preferably with a radiant foil layer too- to avoid the roof dripping when it has a snow load on a warmer than average day- otherwise you'll get awfully wet inside.
Forget about snow load, just need a Mississippi winter night and day. Moisture in the shed condenses on underside of roof, freezes, builds up a little, melts next morning, result rain showers inside if the water doesn't run down the inside of the roof.
I had an inch of "roll" foam applied under the new roof.
