Help me justify a TILLER.
   / Help me justify a TILLER. #1
tony123
Platinum Member
Travelers Rest, SC
YMG2000D
I'm working on a vegetable garden (our first) for next season. The garden will be 3 rows at 4' x 70' or so. This is too much dirt to work by hand, but tillers are a little expensive to be a one dimensional implement.
Can you guys help me with a list of tasks that a tiller works well for? If I could get my uses up to a few projects, my wife would be on board. :eek:
Thank. Tony
   / Help me justify a TILLER. #2
Although I read alot here , due to time constraints , I usually do not post , but since I have my Semi parked for a few days , I'll give you my opinion .
You pretty much hit it on the head being that tillers are 1 dimensional . My neighbor and myself have TC-30 NH tractors . He bought a tiller , ( believe its a 72" ) and although he has used it a few times in his lower field area and it does do nice work it just a couple of passes , the tines take alot of abuse in non-garden type applications , ( rocks are pretty hard on tines ) .
Were as I bought a 72" king cutter disk and have used it pretty extensively for over 3 years now with little damage to any of the blades / disks themselves . It does require a few more passes to get good depth and soil break up , but in the end you would be hard pressed to tell the difference between what was disked versus what was tilled .
I disk down both sides of my driveway to keep weeds down , ( both sides are roughly 25' x 800' each ) , plus I do a 12' border on the south side of our property and the west side for fire protection , ( west side is downhill from home , while south side is both downhill and the normal direction from which the afternoon winds come from ) . Last summer , while I was disking the driveway , he was tilling a section of his field . Although his field came out looking pretty good , since tillers leaves no tracks , I can only imagine what the tines looked like since it was virgin soil . But 2 months later the amount of regrowth was identical both in his field and next to my driveway . So in my opinion , the tiller did no better job working the soil than my disk did . Also after a few passes , my disk will cut just as deep as most tillers will , with alot less strain on the tractor .
If you were looking at a bigger garden area , then maybe I would look at a tiller , but for the size you are stating , I could not justify the cost difference between a disk versus a tiller .
Take Care ,
Fred H.
   / Help me justify a TILLER. #3
I have both a disk and a roto tiller and I use both. I use them for food plots the disk will not work in dry hard ground the tiller always tills.
The tiller tends to collect roots reall well, too well:( . My ground is very hard, clay and rock in fact once while doing some landscaping my shovel was boucing back only breaking small chunks (golf ball size) I got the tiller out and it busted up the ground into powder 4 inches deep:cool:
One other use could be for churning compost, also they are heavy and work well with the front loader work sometime I use it to break up some dirt for digging.
I would not own one if it were not for the food plots.
   / Help me justify a TILLER. #4
I got a great idea!! Go to wally world , buy 2 CHEAP shovels, hand 1 shovel to her,,,,,,,,,,, problem solved!!!!!!!!!
Just kiddin!!! good luck on your aquisition
   / Help me justify a TILLER. #5
Okay I will try my best to help because I think every man should have the equipment he deserve's ... you can till the garden, flowerbeds, yard, fencelines (for fire protection), sides of the driveway for weed controll, you can till the neighbors (Good for neighbor relationship) garden, flowerbeds, yard, fenclines, side of the driveway! Ohhh ... did I mention you can even till the drive way!! Well Now I quess you can just till anything, most importantly you can till your mother in laws garden .... Good Luck hope this helps and you get a tiller!!!
   / Help me justify a TILLER. #7
Thank. Tony
My tiller is a used Yanmar RS-1200 (4-ft wide) that I bought a few years ago for $300. Spent another $150 for a new pto shaft and a slip clutch. Use it with my Kubota B7510HST (21 hp engine, 17 hp pto) for the veg garden and to install a lawn around my new house.
To keep the stresses down on the tiller, I plowed the lawn area with my middle buster plow ($140 at Tractor Supply) before hitting it with the RS-1200.
   / Help me justify a TILLER. #8
I want, therefor I buy. No need to justify a thing. ;)
   / Help me justify a TILLER. #9
I was a little hesitant at first to lay out the money for a tiller, but boy am I glad I did. I till several gardens a year and some were virgin soil. Here in limestone country the tiller hammers on some pretty nasty rocks but it kicks itself off of them or the slip clutch helps out. I use my tiller more than I do my box blade now. I dug out my brother's driveway wider with the tiller, dug out for my above ground pool and dug out for the kids basket ball court. All of these tasks required part of the digging to be at least a foot down, which I had to make a couple of passes. The dirt that I dug up could easily be moved and spread somewhere else as it was smooth and fine. My dad used to do gardens with his double 14 plow and disc and the tiller beat it hands down for QUALITY. The plow and disc are faster, but for smaller sections the tiller is the best, plus you need room to use the disc and plow. My tines are still in great shape after several years of use.
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
2018 Ford F550 Chassis (A55973)
2018 Ford F550...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
Jack Daniels Miniature Decorative Truck (A55853)
Jack Daniels...
2004 GMC Sierra 3500 (A55973)
2004 GMC Sierra...
2013 Nissan Juke SUV (A55853)
2013 Nissan Juke...
