Help me pull the trigger... M6040
/ Help me pull the trigger... M6040 #1
Baldwin City, KS
none yet
Looking at a VERY gently used 2013 M6040. Looks new, <80 hours, very close to me. Planning on going to look at it in more detail tomorrow, and spend some time with it. I have been debating the right tractor for me for the 80 acres we purchased, and this seems big enough to do 90%+ of anything that I would want outside of a full blown hay operation (which I am probably better off hiring out on shares anyway). Key things are mowing (see below), maintaining a 1/4 mile drive, building a shooting range and backstop, general maintenance of the land and some cattle.
What I know:
2013 Kubota M6040 4x4
64hp turbo diesel
Two stacks of rear wheel weights
Joystick loader
left hand reverser
two sets of rear hydraulics
Asking: $32K
tier 2 emissions, seems like a good thing to not have to deal with all the new stuff...
cab, with working heat/air/stereo (will confirm tomorrow)
Was used at an apartment complex for snow removal, and the last few years haven't had all that much snow. Owner is selling because they bought a skid steer and decided to use that for snow removal.
Open questions:
1) This is virtually no usage on a 6+ year old tractor. Anything I should be looking for that could be an issue from sitting too much?
2) I will likely use this for mowing/etc. From my research, it seems that this should pull an 8' mower easily, and likely a 10'. Any thoughts on this?
3) General thoughts on this price? It is strange because the thing is nearly new from a usage perspective, but realistically 6 years old, so all warranties, etc. are over.
The only other interesting used tractor near me seems to be an M5-091 with 700 hours, but that thing is $44K. A lot more tractor, but not sure the extra weight/HP are actually useful for what I need?
Thanks in advance for your thoughts/help.
Sandman
/ Help me pull the trigger... M6040 #2
I think it's a little pricey but it's probably one of the best Kubotas ever made. Is there a cab on it?
Not sure on the price but while you educate yourself and calm your fears, someone will make a deal and snap it up.
There is a cab, should have mentioned that originally. Added it to the original post.
/ Help me pull the trigger... M6040 #4
Now it's not so pricey since it has a cab. Go see it and if it looks as nice as you think, inspect, negotiate a price and leave a deposit. If unsure on mechanical things, take someone along. Presume 8 speed trans, which is good but if a 12 speed that's a home run. That's my two cents.
/ Help me pull the trigger... M6040 #5
I think the tractor is adequate for your needs and appears a good value. The only concerns I'd have would be seals seeping from sitting and stuff like that.
/ Help me pull the trigger... M6040 #6
Sounds good especially for the low hours.
My 2010 Cabbed 6040 had 1100 hrs, loader and single rear remote $26k and I thought that was fair
/ Help me pull the trigger... M6040 #7
View attachment 633293 . This is my 2009 Kubota M6040. Bought new in 2009. It's been a real joy to operate. Absolutely no problems at all. I have it, more or less, maxed out weight wise. 820# grapple on the FEL - 1550# of RimGuard in the rear tires - 1050# Rhino 950 rear blade. Total weight - 10,100#.
I have 80 acres to play on and a mile long gravel driveway to maintain.
With a cab and heat & air its not such a bad price for low hours. One other thing - this tractor will need Class 2 implements to function at its highest capacity. There is a significant price jump going from Class 1 to Class 2.
On a used tractor gage its condition more on hours of use as opposed to years from date of manufacturer. With less than 80 hours - it isn't even broken in yet.
As previously stated - I've had not one single problem with my Kubota.
One last thought - if you do purchase the M6040 - - ask the owner to give you the Operator Manual. There is a lot of good info in the manual. Your local Kubota dealer should be able to get one if the original is "lost".
/ Help me pull the trigger... M6040 #9
Buy it. Buy it now. If you don’t, PM me know the contact please and I will send the guy a deposit tonight.
I have a 2012 M7040 I bought with just under 1000 hours and gave the same price. Nothing but tickled with the tractor.
/ Help me pull the trigger... M6040 #10
If the owner doesn't have the Owner's Manual it should be available on line. I have the hard copy for my M7060 but I also downloaded the PDF version to keep on my computer for quick reference...it's what I do screen shots of to prove a point when I see silly incorrect information being posted on this site. PDF version is free.
/ Help me pull the trigger... M6040 #11
Once it's on your property you will forget about the price.
It's Christmas, you've worked hard your entire life it's time you did something for yourself.
Most guys work hard and give things up for the family but every now and they a man must say THIS IS FOR ME, and be happy about it.
Then get in it, turn on your favorite music and enjoy life.
That was my decision process for my 4060 cab. When I'm in it and the tunes are playing or I'm listening to some good talk radio, that's when I'm
in my happy place.
/ Help me pull the trigger... M6040 #12
Exactly Cat_Driver. What StAngerSandman has found is as close to a "barn find" as most of us could ever expect. I will be most interested to see what happens here.
Thanks for all of the comments and thoughts!
I Took a look at both the 6040 and the M5-091 yesterday. Both are in AWESOME shape, and at 75 hours and 700 hours, they are both pretty darned new. The only question now comes down to which one I want. Definitely going orange, just dialing in the right size. Lucky to have a few good options (just saw a 7060 posted with 270 hours near me as well for $37K)
Wanted to get this done today, but daughter's water pump went out, and got to spend the day working on that.
So between those 2:
1) I REALLY like the bigger tractor (who wouldn't!) but honestly don't know that I have any needs for the additional size/HP that I can come up with... :(
2) Difference is $11K, so definately not pocket change for not knowing why I want the bigger one.
3) I like that the 6040 is Tier 2 emissions, doesn't have DEF to worry about, etc.
Now it all comes down to size and price. All 3 are priced really well for what they are, it just comes down to picking the right size for me. Having not bought and sold a lot of tractors, my current thought is to jump on the 6040, and given the low hours and awesome condition, I can always sell it later if I realize I really do need something bigger.
Think I'll call him in the morning and lock it down. Will post pictures as soon as I own it.
Sandman
/ Help me pull the trigger... M6040 #14
7060 = tier 4 :thumbdown: 10 hp more :thumbsup: 11,000 $ more :thumbdown: 6040 great shape :thumbsup: cab :thumbsup: tier 2 :thumbsup: If you don't absoulty need the 10 hp I think it's a no brainer. 6040 all the way :dance1::drink:
/ Help me pull the trigger... M6040 #15
I would go for the 6040 for the simpler emissions system (Parts are expensive and repairs are more complicated).
Given there are so few hours on it, I'd consider draining any diesel from the tank and refilling with fresh fuel treated with a biocide. Of course this would be a preventative measure that might not be needed, but it's not fun dealing with the repercussions.
Let us know when you complete the transaction.
/ Help me pull the trigger... M6040 #16
If it's truly a good price, it'll be gone by tomorrow.
After digging in a little more, I don't think this is the one for me. Back to the drawing board... :(
/ Help me pull the trigger... M6040 #20
I really live my M7040, but I wish I had gone with an M5. There are times I definitely wish I had more tractor, but even if I went with an M5 I would probably wish I got an M6. I suppose this is the way it goes.
I recently just purchased a new SVL75 track loader and am finding my wish of more tractor is subsiding now.
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
AKS ALASKA STRUCTURES PORTABLE TENT (A63276)
AKS ALASKA...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
1993 International 4900 Ram Rodder Combination Sewer Jetter Vacuum Truck (A64194)
1993 International...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
