Help! My Cub is only running so-so now!
   / Help! My Cub is only running so-so now! #11
Wayne - My '66 started doing the same thing. Rebuilt the carb and good as new. Probably a vacum leak between the top and bottom parts of the carb. Gasket may have dried out and cracked. Chuck
   / Help! My Cub is only running so-so now! #12
</font><font color="blue" class="small">( Flyweights in ignition advance?? Cubs don't have timing advance )</font>
The distribuitor does have automatic spark advance, via centrifugal flyweights in the distribuitor.
If you have an I&T IH50 servic manual.. look up figure IH20.. it shows the exploded distribuitor diagram. the weights are #11 in my book. Paragraph 31 speaks of the automatic spark advance.
A quick look at the original cub and cub low boy manual I have shows the battery ignition unit as a 16 degree advance type.. but does not mention advance on the magneto units.
Soundguy
You have a good point. Prior to this, (after sitting) I could not get it started. I then noticed that gas was dumping out of the carb. (the air intake to the left) I took the carb apart thinking the float was not working and not shutting off the little valve to stop the gas flow into the chamber of the carb. Tested the float. ok. Put it all back together and the Cub started. Not really sure why the gas flow was not being shut off. (I mean, after I noticed I couldn't stop it. Until I shut off the flow by the fuel filter)
Maybe now that's it's all back together I should replace that gasket in carb.
   / Help! My Cub is only running so-so now! #14
I just recently had to replace the feul bowl/gas valve on my 66 cub as I noticed it leaked gas, and fille dup my crankcase...
Soundguy
Unfortunately, (yeah, right) my new B7610 has arrived. I prob won't have too much time to play with the ol' Cub now that the new toy is in town. (too much landscaping to do with the loader for the fall) Though I will try that gasket if I get a little free time.
American G-Model Pump Jack (A53473)
American G-Model...
2003 Peterbilt 330 T/A Progress A90LS 4,500 Gallon Fuel Truck (A51692)
2003 Peterbilt 330...
2009 Dodge Grand Caravan Passenger Van (A53117)
2009 Dodge Grand...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
2015 Infiniti QX60 SUV (A51694)
2015 Infiniti QX60...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
