RickB
Super Star Member
- Joined
- Sep 18, 2000
- Messages
- 15,143
- Location
- Up the road from Dollar General WNC
- Tractor
- Just a Scag
I did the same thing to my New Holland and at about the same ratio of gas to fuel. It would start and run, but then lose so much power I could barely keep it running. When I figured it out I drained the tank into a gas can and re-filled with diesel. Then bled the fuel system until it was getting pure diesel to the injection pump. No filter change needed, and no oil change needed. At that point I cracked the injector lines and let out some more contaminated fuel by cranking it at full throttle. Then tightened the injector lines, started it up and went back to work. No damage and it runs fine.
Adding an additive, after the fact, won't do much. Changing the oil does nothing for the problem as you won't find any gas in the crankcase. Forget the oil change idea, it's the fuel side that needs attention.
You can use the contaminated fuel to start your burn pile, or re-cycle it with your used engine oil, or add small amounts to your tank in the winter months to prevent gelling and recover some of your expense.
Best response yet.
