Help - need new roof, 2:12 pitch
   / Help - need new roof, 2:12 pitch #1
450EXC
Central NY
Kioti CK30
This roof is almost flat. I started looking at rubber but that might be a little tough with the contact cement adhesive. I found the 3' rolls of peel and stick modified bitumos that looks pretty easy. Then I caved in and talked to the guys at....oh no.. home depot. Come to find out they have metal roofing that is rated for low pitch. I think metal would be much better for the snow up here in the northeast.
Anyone have any expierence with low pitch or flat roofs ?
Thanks in advance, Larry
   / Help - need new roof, 2:12 pitch #2
They leak and hold lots of leaves and your snow will stay right where it lands, not a good idea. Think about this, it snows 60 inches and you have 60 inches on your roof?
Not for me. I lived in Maine for over 30 years and snow is heavy
Jim
   / Help - need new roof, 2:12 pitch #3
I have a metal roof from Home Depot - It is not as flat as yours but I can tell you that my roof is clear of snow much faster than any of my neighbors house with shingles. I can also tell you that you do not want to be on the roof when it has even just a frost on it, you will fall on you behind - It is slick! I have a fairly flat porch roof as you can see in the picture. It is corigated. Now that I have a metal roof I will not have any other. We get some strong winds around here and I see shingles lift and remove all the time on other houses.
I have had the roof for three winters and have not had a problem with leaking. I bought special screws with good neopreme washers and forced myself to use the clutch on my drill so I did not over tighten and squish the washer out.
   / Help - need new roof, 2:12 pitch #4
Larry one other option would be low pitch shingles whith ice shield, this would be cheaper to install then metal roof...cag
   / Help - need new roof, 2:12 pitch #5
Being in the snowbelt with a low roof like that would scare me. I would rip the roof off and replace the entire roof with a much steeper pitch. One of my neighbors has a flat roof. They spend a lot of time shoveling it in the winter.
   / Help - need new roof, 2:12 pitch #6
I'm in agreement with Jim. If it's an option take it up to a 4/12 or even a 5/12 pitch, the latter is what we have.
   / Help - need new roof, 2:12 pitch #7
If money not a problem, eck go fo it...cag
   / Help - need new roof, 2:12 pitch #8
We had a house with a flat roof addition- and lived in very snowy area. The only problem we had was a failure where the addition met the pitched roof. Ended up having that section of roofing replaced by a flat roof company. It was some type of rubberized membrane. Yes, I had to remove the snow about once a winter- but used a snow scoop which was very neat. If you are going to stay with a flat roof, look into some companies that do them alot. Yes, it's going to cost, but the alternative isn't cheap.....
   / Help - need new roof, 2:12 pitch #9
I have a flat roof over an addition. Unfortunately, the pitch can not be raised without covering up windows. The previous owners had a hot tar roof, it leaked a few years after we bought the place. I put on another hot tar roof. Leaked after less than 10 years. I replaced it with a rubber roof. It's the best thing I ever did. Yep, I have to shovel it every now and then, but I use a plastic shovel and am very careful about the angle I hold the blade at. Fortunately, I can push most of the snow off, no lifting necessary. Ironic that I use the tractor to plow several driveways and have to shovel my roof.
The front porch roof is a little steeper. I covered the whole roof with ice and water membrane and shingled over that. I get to shovel this roof too. Did I mention the main roof? The roof rafters in our 100 year old house are not the best. I occassionally shovel this roof with a roof shovel. I don't like winter.
Back to your almost flat roof. Install a rubber roof on it.
   / Help - need new roof, 2:12 pitch #10
Good advice. Shingles and metal are not preferred for that application IMO.
2025 Unused LandHero LDH-T460XX Ride-On Mini Skid Steer (A52377)
2025 Unused...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
72'' power rake (A53421)
72'' power rake...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
