help needed to find parts for heatr in cab
   / help needed to find parts for heatr in cab #1
etcallhome
Platinum Member
WV,Preston County
JD 1026R
Parts for a 2305 and looking for parts that only Curtis cab seems to have
Where besides a JD dealer ,then ordered from Curtis Cab, could I get the fittings to connect a cab heater.
I bought a heater from a person and it had no fittings with the unit.
Checking w/ local jd dealer he wanted over $125.00 just for the 2 of the 3 items I would need . Then checked with dealer where my son-in-law bought his jd and they wanted close to a $100. but they would mail me the parts. Parts would be coming from Curtis Cab,
One is a 3/8 univ tee w/ plastic bushing and the other was a 1" tee to 3/8 in middle.
I have searched net and had no luck finding the univ tee.
Had gone to Lowes and tried using 3/8 brass to make the tee. but will not tread in
I just hate thinking of paying $100. just for these two items.
   / help needed to find parts for heatr in cab #2
Ask a plumber or stop by a good plumbing supplier. I can tell you as a plumbing and heating contractor it can't be that difficult to match up.
Steve
It seems like the 3/8 should thread in , the sending unit threads into the brass tee. Just connot get the nipple to thread into the tractor part.
   / help needed to find parts for heatr in cab #4
Sounds like you need to make sure the threads and size are a match. What did you remove to gain access to the hole? Whatever was removed could be checked against a tap or die to confirm whether you have the proper size nipple. It may be metric or fractional and you need to know for sure.
Steve
I removed the temp sending unit. I had a 3/8 brass tee the sending unit would screw into the tee. but could not get the 3/8 nipple into the sending unit location.
according to Curtis Cabs website the fittings are NPT
Here is the part that I'm trying to locate
Dorman makes a nipple that lloks a lot like this but not a tee
I may call them and see if they have a part like this
Hope this works
   / help needed to find parts for heatr in cab #8
Hope this works[/QUOTE
If the sender unit you removed was 3/8 npt and yet the 3/8 npt nipple will not screw in you should chase the threads with a 3/8 npt tap. I would not be to concerned about finding the specialty fitting in the picture but would instead buy a 3/8 hose nipple and a standard 3/8 tee and make it up.
Steve
Thanks that is what I'm going to try and do .
Will try and get this done over the summer mos.
Thanks for everyones help
1999 Blaw-Knox PF 161 Paver (A52384)
1999 Blaw-Knox PF...
1988 John Deere 310C Backhoe (A52384)
1988 John Deere...
43029 (A51691)
43029 (A51691)
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2025 New/Unused Min Skid Steer Loader (A51573)
2025 New/Unused...
