help needed to find parts for heatr in cab
   / help needed to find parts for heatr in cab #1
etcallhome
Platinum Member
WV,Preston County
JD 1026R
Parts for a 2305 and looking for parts that only Curtis cab seems to have
Where besides a JD dealer ,then ordered from Curtis Cab, could I get the fittings to connect a cab heater.
I bought a heater from a person and it had no fittings with the unit.
Checking w/ local jd dealer he wanted over $125.00 just for the 2 of the 3 items I would need . Then checked with dealer where my son-in-law bought his jd and they wanted close to a $100. but they would mail me the parts. Parts would be coming from Curtis Cab,
One is a 3/8 univ tee w/ plastic bushing and the other was a 1" tee to 3/8 in middle.
I have searched net and had no luck finding the univ tee.
Had gone to Lowes and tried using 3/8 brass to make the tee. but will not tread in
I just hate thinking of paying $100. just for these two items.
   / help needed to find parts for heatr in cab #2
Ask a plumber or stop by a good plumbing supplier. I can tell you as a plumbing and heating contractor it can't be that difficult to match up.
Steve
It seems like the 3/8 should thread in , the sending unit threads into the brass tee. Just connot get the nipple to thread into the tractor part.
   / help needed to find parts for heatr in cab #4
Sounds like you need to make sure the threads and size are a match. What did you remove to gain access to the hole? Whatever was removed could be checked against a tap or die to confirm whether you have the proper size nipple. It may be metric or fractional and you need to know for sure.
Steve
I removed the temp sending unit. I had a 3/8 brass tee the sending unit would screw into the tee. but could not get the 3/8 nipple into the sending unit location.
according to Curtis Cabs website the fittings are NPT
Here is the part that I'm trying to locate
Dorman makes a nipple that lloks a lot like this but not a tee
I may call them and see if they have a part like this
Hope this works
   / help needed to find parts for heatr in cab #8
Hope this works[/QUOTE
If the sender unit you removed was 3/8 npt and yet the 3/8 npt nipple will not screw in you should chase the threads with a 3/8 npt tap. I would not be to concerned about finding the specialty fitting in the picture but would instead buy a 3/8 hose nipple and a standard 3/8 tee and make it up.
Steve
Thanks that is what I'm going to try and do .
Will try and get this done over the summer mos.
Thanks for everyones help
7046 (A50322)
7046 (A50322)
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2022 Chevrolet...
UNUSED JCT 2 PRONG BALE SPEAR (A54757)
UNUSED JCT 2 PRONG...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
10ft Enclosed Cargo Trailer (A55758)
10ft Enclosed...
10 GALLON SANDBLASTER (A54757)
10 GALLON...
