Oct 12, 2010 / Help please to drain fuel tank #1 J joesb1 New member Joined Oct 12, 2010 Messages 2 Tractor kubota bx2660 I made a mistake and add gasoline to my diesel fuel Kubota BX2660 tractor. How can I drain fuel?
Oct 12, 2010 / Help please to drain fuel tank #2 bp fick Super Member Joined Aug 15, 2009 Messages 5,645 Location Beaver Creek, Northern Michigan Tractor John Deere X390 Under your tractor, toward the rear, you will find an in-line fuel filter. I'd simply take that off and let gravity do it's job. Hopefully, you caught your mistake before turning on the key, or running it?
Oct 12, 2010 / Help please to drain fuel tank #3 bp fick Super Member Joined Aug 15, 2009 Messages 5,645 Location Beaver Creek, Northern Michigan Tractor John Deere X390 You should look near your HST white cooling fan. The in-line filter is white, clear and easy to spot. The quarters are a bit cramped, but you can do it.
Oct 12, 2010 / Help please to drain fuel tank #4 Y yooper1 Veteran Member Joined Feb 1, 2006 Messages 1,189 Location U. P. of Michigan Tractor New Holland T1510 Hello and welcome to TBN Also, you may want to post your Kubota questions in the Kubota section where more members may see it bpfick is good for info like always , but you may get more views in the Kubota section
Oct 12, 2010 / Help please to drain fuel tank #5 L LBrown59 Super Star Member Joined Oct 27, 2004 Messages 16,831 Location First organized permanent settlement in the northw Tractor 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500 joesb1 said: I made a mistake and add gasoline to my diesel fuel Kubota BX2660 tractor. How can I drain fuel? Click to expand... Diesel is in the yellow can and gas is in the red can.
Oct 12, 2010 / Help please to drain fuel tank #6 Egon Epic Contributor Joined Aug 14, 2001 Messages 22,507 Location Nova Scotia, Canada Diesel is in the yellow can and gas is in the red can. Click to expand... But I only got red cans.:thumbsup:
