Traction Help Removing Steering Wheel - GC1700
   / Help Removing Steering Wheel - GC1700 #21
Ok, this is something that ought to be really simple and straightforward.
The shop manual says that all I need to do is remove the center cap with a screwdriver, remove the nut securing the wheel to the splined shaft, pull up on the wheel to remove it.
Yeah. That's not working. No matter how hard I pull.
I've put a piece of wood across the underside of the steering wheel grip to gently hammer it up-no worky.
I bored a hole in that piece of wood and used a threaded dowel, nut, and washer to apply force from the center splined shaft upward against the underside of the wheel grip as I thread the nut upwards. Still doesn't release. Even while tapping as I do it.
During all of this, I'm applying penetrating spray to it.
I started to use two screwdrivers to press up against the flat side of the orbital valve under the wheel to pop the wheel off. Still nothing.
I don't want to use a 3 claw clamp because it could ruin the wheel. I'm trying my absolute best to do this with care.
Anyone else have any ideas?
Flood the center cavity (where the nut sits) with Kroil, and keep it flooded.
Let it sit for at least a week, with the nut on the threads, tapping that nut with a hammer every time you think of it.
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
PENDING SELLER CONFIRMATIONS (A57880)
PENDING SELLER...
