Help removing the clutch on Bcs 720.
   / Help removing the clutch on Bcs 720.
Thanks. Will do. I initially thought that the shaft on the B&S was going to be 3/4" but it turned out to be 1". So I'm returning the smaller Predator and going up to the 8 hp one. That's what I was wanting anyway.
I got the engine installed two days ago but have yet to run the break-in.(I spent two days trying to catch a tiny 6 week old kitten some *##hole dumped in the briars in the ditches across the road from my house. Then 4 hours today at a vet's office. Found it a new home though:) ) Anyway, I did start it and was pleased that it did start on the first pull. The only hang-up I had was the key provided with the Predator was too large. I wound up reusing the old key from the Briggs which let the clutch fit the shaft perfectly. The new engine is rather quiet which is very nice.
I had been concerned that there may be a transmission problem because the tractor didnt want to move when placed in neutral, even with the engine removed. But after I got the engine installed, I started it up, put it in gear, then back into neutral....still the wheels wouldn't move in neutral. I got a bit ticked and decided to drag it out from under the shop roofline and after about 10 feet, it finally broke loose and the wheels started to turn. I was very relieved. Now I have the tines on order and they should be here on Monday. I've already soaked the old bolts in penetrating fluid so hopefully they will be cooperate and come loose. I may be on my way to tilling next week!
   / Help removing the clutch on Bcs 720. #13
Congratulations! Sounds like you have a winner.
We bought a 26" Berta flail mower for our 720. Wife says I've turned into a 'flailing fanatic'.
Cheers.
Congrats on the flail mower.
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
CATERPILLAR V50B STRAIGHT MAST FORKLIFT (A51246)
CATERPILLAR V50B...
JOHN DEERE 700M LOT NUMBER 35 (A53084)
JOHN DEERE 700M...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
