Help reseating zerks on BX MMM anti-scalp wheels?
   / Help reseating zerks on BX MMM anti-scalp wheels? #1
crd
Keene, NH
BX2350
Today two of my four anti-scalp wheel zerks pulled completely out when I removed the grease gun. I felt slightly less foolish after a quick TBN search showed this to be a common problem. I fussed with them and they sort of went back in, but they still look like they'll pull out again at the next service.
Any tips on how to permanently repair these litle things?
   / Help reseating zerks on BX MMM anti-scalp wheels? #2
I take it they are press in style. If you can I would suggest threading the holes and installing screw in style grease fittings.
   / Help reseating zerks on BX MMM anti-scalp wheels? #3
I second DieselPower's recommendation to replace them with thread-in zerks.
I just did one myself a couple of days ago. It requires that you drill out the hole (i don't recall the bit size used) and then thread it with a 1/4" X 28 tap. Not hard at all and it makes a permanent zerk (unless you hit something and break it off!).
Good luck,
Dave
   / Help reseating zerks on BX MMM anti-scalp wheels? #4
The same thing happens to me. The actual Zerk fittings are threaded type but I think the wheel openings are either not threaded or the plastic is too soft to hold the threads. After removing the fitting from the en of the grease gun I push them back into the opening. So far, 150 hours, they have remained there until the next time I grease them.
   / Help reseating zerks on BX MMM anti-scalp wheels? #5
What size deck is it ?
Where do you have anti-scalp wheel zerks ?
I have a BX22 with a 60" deck and there are no zerks on the wheels. Just plastic wheels on a steel pin.
paul
   / Help reseating zerks on BX MMM anti-scalp wheels? #6
The new decks now have grease zerks on the anti-scalp wheels. I finally bought a deck for my BX and they have zerks.
Dave
   / Help reseating zerks on BX MMM anti-scalp wheels? #7
I have an older deck without grease fittings and at one point one of the anti-scalp wheel melted around the bolt. What a mess to get the bolt out and get a new wheel. Since I did not know the new wheels came with grease fittings I drilled a hole down the center of the bolt and a hole through the bolt to let the grease out of hole in the bolt. I thenthreaded a zerk fitting in the hex head end. They work great and I never have to worry about pulling them out of the platic.
Just a thougt
Wow, nice solution! I guess for now I'll just keep pushing them back in like Tommy V suggests. Then, since I don't have a machine shop, maybe send my old ones this winter for the wheel upgrade that Larry sells. Looks very similar to what you did on your own.
GMCKIRCH said:
... drilled a hole down the center of the bolt and a hole through the bolt to let the grease out of hole in the bolt. I then threaded a zerk fitting in the hex head end...
   / Help reseating zerks on BX MMM anti-scalp wheels? #9
I had Larry do my wheels. They are great! I am going to send in the ones off my ZD326 at the end of the season to have him do them as well.
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A52472)
2012 TEX MEX...
43024 (A51691)
43024 (A51691)
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
