HELP! - Squeaking noise coming from front wheel?
   / HELP! - Squeaking noise coming from front wheel? #11
I had a Grand Am that did that and it was the brake hardware. The thin metal pieces between the caliper and pads. It made no difference on application. They lost their tension and let the pads vibrate. Cheap to fix.
   / HELP! - Squeaking noise coming from front wheel? #12
Another reason I do my own work is getting it done right. When you replace brake pads, you should use an adhesive like "disc brake quiet" to "glue" the pads to the bracket and piston so no squeaking when the pads slide around.
Thank you all for the replies and advice!
I took it back to the shop and had them look at and take it for a drive. They could not hear anything, so the mechanic had me take him out for a ride. Once I pointed it out to him, he then could hear it. He took it back and looked at the wheel/brake area and did not see anything, so he greased it up and put it back together (all for free of course). The noise continued for a few minutes and then it stopped and has not been back since. :confused:
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2008 FORD F-350 SUPER DUTY (A58214)
2008 FORD F-350...
2023 yamaha (A55758)
2017 Ford F-550 Duralift DTAX39 39ft Insulated Bucket Truck (A55973)
2017 Ford F-550...
LOT: (3) NEW Hi-Run 26 x 12.00-12 Lawn & Garden Tires (A59076)
LOT: (3) NEW...
