haybaler9 said:
ok, 9 out of 10 times when I go to start tractor it grinds (not clicks) 2or 3 times then starts. .......anyone have any ideas?
When it GRINDS, is it a high-pitched Zing or a low crunch? If it zings that sounds like the starter motor is starting to spin up before the starter pinion (small gear) is fully engaged with the ring gear (large gear on the flywheel). There can be different causes for this.
One cause is when the spring on the starter pinion is broken and doesn't shove the pinion all the way in before the motor starts. The fix for this is a new Bendix drive - includes the spring, pinion gear, and small over-running clutch.
Each time it grinds, the pinion gets a little damage - the ends of the gear teeth lose the nice taper they had when new, making it more likely to grind again next time. These things engage on the fly, so everything has to be smooth to work right.
Another possible cause is the starter drive is not the right one for the tractor and doesn't have enough reach - it doesn't push the pinion far enough in to fully engage the ring gear.
Whatever the root cause it is important to fix it as soon as possible. Each time it "grinds" the pinion is chewing away on the ring gear too - eventually it makes a worn area that even a new starter won't fix.
To make matters worse, the engine always stops in one of 2 or 3 positions so its these areas on the ring gear that get all the wear. Replacing the ring gear is a big deal - it means splitting the tractor - which tends to be hard on your checkbook. BTW, each time it grinds, it does actually turn the engine a little bit, and it eventually gets past the worn spot.
I know about this because BMW's 6-cylinder cars were susceptible to this in the '70s - their starters didn't have heavy enough springs in the bendix drive. This sounds very similar. It may just need a starter drive, but if not fixed it may eventually need much more.
Hope this is useful. As always, prompt cheerful refund if info is bogus.
