help to convert brush hog from shear pin to slip clutch
   / help to convert brush hog from shear pin to slip clutch #1
rkallaman
KNox, Pa
JD 1025R
I want to convert a 4' brush hog (Brush Hog brand) from a shear pin PTO over to a slip clutch. What do I need to know to be sure what I buy will fit when I get it home. Don't want to buy a wrong non returnable slip clutch. Any suggestions as were to buy a slip clutch?
   / help to convert brush hog from shear pin to slip clutch #2
Generally you need to know whether the gearbox input shaft is splined, or smooth, and the diameter of the input.
I had to buy some PTO shaft tubing recently, and Agrisupply.com seemed to have the mist comprehensive list of parts. You can also check with Tractor Supply....they have a fair selection as well.
On a spline shaft do you measure the dia. outside to outside of splines or solid part of shaft. Does the width & depth of a spline need to be measured or just the number of them?
Danhauser 3 pt Post Hole Digger (A50515)
Danhauser 3 pt...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
2017 DODGE RAM 5500 HEAVY DUTY SERVICE TRUCK (A51243)
2017 DODGE RAM...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2012 PETERBILT 337 (A50854)
2012 PETERBILT 337...
2018 Dodge Grand Caravan SXT Van (A50324)
2018 Dodge Grand...
