Help to hook up Prince flow control valve
   / Help to hook up Prince flow control valve #11
His valve is the same as yours.
What are you trying to do with the EF fluid.
The EF fluid can go to a return line which is tank, or feed another valve.
I want to use it to control the speed on my wood elevator. Right now it is to fast
How would I go about determining if fluid is in the line? I have the standard Bobcat flat-faced hose quick connects. Also, I would assume if it (the return line) were under pressure, it could be dangerous to try and push on the connector end with a screwdriver or something to see if it squirts out. What do you think the best way to test a return line safely. Again, I'm a complete hydraulics novice. Thanks for your response. Mark
   / Help to hook up Prince flow control valve #13
You should look for a return hose close to the tank, remove it and place in a bucket, start engine and see if fluid flows into bucket.
Only do this at idle for a few seconds.
A hyd gage might help you troubleshoot your hyd system also.
A closed center valve will usually will have standby pressure with all valves in neutral, and nothing going to tank through the return hose. The return or OUT hose is usually reserved for cyl expended fluid.
Your return line should not have very much pressure, as back pressure is not desired.
I'm going to give this a try after the holiday weekend. This is the most comprehensive advice I have found about my specific issue. Thanks so much for your follow ups. It is such a help when you are out of your element on a particular subject to have someone take the time share their insight and guidance. I really do appreciate you. Thanks again. You have done your good deed for the day. To be continued....... Mark
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2014 Chevrolet Cruze Sedan (A55758)
2014 Chevrolet...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
Loader Bucket (A55787)
(APPROX.100) UNUSED FUTURE 12' GALVALUME STEEL TIN (A54757)
(APPROX.100)...
