Help! Tractor tries to start in the "run" position.
   / Help! Tractor tries to start in the "run" position. #1
Seanachie
Western Kentucky
I just replace the wiring harness on my 1972 Ford 4000 (three cylinder diesel). I'm wondering if fixing the jury-rigging has revealed other problems.
I have the three-position ignition switch, which actually has 4 (Acc/Off/Run/Start) positions but it is only designed to remain in three of them (Acc/Off/Run).
Here's the problem: From the "Off" position, as soon as I turn the key to the right to the "Run" position, it cranks the engine. The engine does not start but it keeps cranking until you turn the key back to off. If you turn it all the way to the "Start" position, it still keeps cranking but it never catches and starts.
FYI: The safety start switch (neutral safety) is inop but I just bypassed the connections until I can get a new one tomorrow.
Do you think the ignition switch is bad or does anyone have any ideas what's going on?
Thanks for any help you can provide.
Sean
   / Help! Tractor tries to start in the "run" position. #2
Seanachie said:
Here's the problem: From the "Off" position, as soon as I turn the key to the right to the "Run" position, it cranks the engine. The engine does not start but it keeps cranking until you turn the key back to off. If you turn it all the way to the "Start" position, it still keeps cranking but it never catches and starts....
Sean
I would say it is a bad switch, if you are restoring the tractor to working condicion I would go to my local autoparts store and get a replacemtn switch, they sell them for dune buggies and the like... ~$25 IIRC
Aaron Z
   / Help! Tractor tries to start in the "run" position. #3
It may be wired incorrectly also.
   / Help! Tractor tries to start in the "run" position. #4
I would completely disconnect the ignition switch and check it with an ohmeter to see that it was working properly. If it is, then you need to check your wiring for a problem.
I was thinking it might be that too but I can't figure out any combination of miswiring that would cause it to act like that. Any ideas?
   / Help! Tractor tries to start in the "run" position. #6
Jinman gave you all the info you needed.
If the run/start tabs of the ignition switch areinternally shorted, it would cause this.
As for misswireing causing this? check to make sure the line running to the starter soldenoid thru the now bypassed safety switch only feeds off of one terminal.. IE.. make sure 2 wires don't join somewhere due to a previous owners miss wireing.
Start with the switch and an ohm meter though..
soundguy
   / Help! Tractor tries to start in the "run" position. #7
Perhaps the wire going to the starter solenoid is connected to the Run terminal and maybe the Ignition coil wire is on the Start if it is connected at all.
larry
   / Help! Tractor tries to start in the "run" position. #8
larry
I may be all wet here.. but the original poster did say "1972 Ford 4000 (three cylinder diesel)"
So i really.. REALLY doubt there is an ignition coil on this thing! ;)
soundguy
soundguy
I think Larry meant the "ignition terminal" on the back of the starter. Turns out that there were two problems: The switch was indeed bad and the new wiring harness had two wires the wrong color, so they got reversed. It's all good now! :)
2016 KENWORTH W900 DAY CAB (A57880)
2016 KENWORTH W900...
EZ loader trailer (A56857)
EZ loader trailer...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
Case Backhoe (A55973)
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
