westsail434
- Joined
- Dec 18, 2011
- Messages
- 10
- Location
- Okefenokee Swamp
- Tractor
- Hinomoto C174, Kubota 3901 backhoe,FEL, grapple, other attachments, John Deere 170, 3 Murray 12 hp rough cuts, Stihl chainsaws, Stihl trimmers,, Ryobi tiny tiller
Old newbie needs your expertise. My Hinomoto C174 alternator light has been running dim for several years but now it just got brighter. I only have 12.34 volts at the battery when running at 1500 rpm. The tiny generator, I would presume, has two black then a connector changes them to blue wires and they go under the dash. Can I disconnect the quick connect and check for voltage there and what should I get? This is the easiest thing to do, short of just forgetting the charging circuit altogether. Is there a way to check if it is the voltage regulator, buried under the dash, if I do decide to tear the dash apart? Any help would be greatly appreciated.
